NEC M300XS LCD XGA Short-Throw Projector - 3000 ANSI Lumens
Quicklinx: 7FGKWS00 Mfr#: 60003076
  • High-Definition Multimedia Interface (HDMI)
Get great performance while saving the environment. Advanced Eco features help to substantially lower your operating cost without compromising on quality and flexibility. Less shadow and glare gives the presenter more space to engage with his audience enhances the experience with interactive white boards.
The M300XS is particulary suited for classrooms and small to medium sized meeting rooms.
  • Enhanced audio experience
    With integrated 10 W mono speakers, this projector delivers clear and powerful sound, enhancing any presentation or multimedia content.
  • Versatile connectivity
    Equipped with a wide range of interfaces including HDMI, S-Video, composite video, and multiple audio line-ins and outs, this projector offers flexible connection options for various audio and video sources.
  • Optimized image quality
    Featuring a high contrast ratio of 2000:1 and native XGA resolution (1024 x 768), the projector ensures sharp, detailed images and vibrant colors for an exceptional viewing experience.
  • Eco-friendly operation
    With Eco-Mode technology, the projector reduces power consumption and extends the lamp life up to 5000 hours, promoting energy efficiency and lowering operating costs.
  • Precise image control
    Manual focus and vertical keystone correction allow for precise image adjustments, ensuring the perfect alignment and distortion-free projection in any setting.
NEC M300XS - LCD projector
LCD projector
Built-in Devices
Speaker
Brightness
3000 lumens
Contrast Ratio
2000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
230 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 5000 hour(s) - economic mode
Video Input
RGB, S-Video, component video (NTSC, SECAM, PAL, PAL-M, NTSC 4.43, PAL 60)
Digital Video Standard
Video Modes
480p, 720p, 480i, 576i, 576p, 1080/60i, 1080/50i
Speakers
Speaker(s) - integrated
AC 120/230 V (50 - 60 Hz)
302 Watt
39.8 cm x 31 cm x 15.2 cm
4 kg
3-year warranty
LCD projector
Built-in Devices
Speaker
Projector
Brightness
3000 lumens
Contrast Ratio
2000:1
Image Size
152 cm - 279 cm
Throw Ratio
0.47:1
Resolution
XGA - XGA (1024 x 768) (native) / 1680 x 1050 (resized)
Native Aspect Ratio
4:3
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
230 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
Eco-Mode technology, Color Management System, freeze frame, Micro Lens Array (MLA) Technology, JPEG photo playback, wall colour correction, Deep Color, DICOM Simulation Mode
Lens
Focus Type
Manual
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-20 / +20
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Input Device
External
2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x HDMI , 1 x S-video input - 4 pin mini-DIN , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type B , 2 x USB 2.0 - 4 pin USB Type A
Lens cover, wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection
TUV GS, RoHS, GOST-R
302 Watt
Power Consumption Operational (Standby)
0.4 Watt
Software Included
Drivers & Utilities
39.8 cm
31 cm
15.2 cm
4 kg
Limited warranty - 3 years , Limited warranty - lamp - 6 months / 1000 hours
5 °C
20 - 80%
Sound Emission
35 dB
29 dB
