Get great performance while saving the environment. Advanced Eco features help to substantially lower your operating cost without compromising on quality and flexibility. Less shadow and glare gives the presenter more space to engage with his audience enhances the experience with interactive white boards.
The M300XS is particulary suited for classrooms and small to medium sized meeting rooms.
Enhanced audio experience
With integrated 10 W mono speakers, this projector delivers clear and powerful sound, enhancing any presentation or multimedia content. -
Versatile connectivity
Equipped with a wide range of interfaces including HDMI, S-Video, composite video, and multiple audio line-ins and outs, this projector offers flexible connection options for various audio and video sources. -
Optimized image quality
Featuring a high contrast ratio of 2000:1 and native XGA resolution (1024 x 768), the projector ensures sharp, detailed images and vibrant colors for an exceptional viewing experience. -
Eco-friendly operation
With Eco-Mode technology, the projector reduces power consumption and extends the lamp life up to 5000 hours, promoting energy efficiency and lowering operating costs. -
Precise image control
Manual focus and vertical keystone correction allow for precise image adjustments, ensuring the perfect alignment and distortion-free projection in any setting.
- NEC M300XS - LCD projector
- LCD projector
- Built-in Devices
- Speaker
- Brightness
- 3000 lumens
- Contrast Ratio
- 2000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Bulb type
- 230 Watt
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 5000 hour(s) - economic mode
- Video Input
- RGB, S-Video, component video (NTSC, SECAM, PAL, PAL-M, NTSC 4.43, PAL 60)
- Digital Video Standard
- High-Definition Multimedia Interface (HDMI)
- Video Modes
- 480p, 720p, 480i, 576i, 576p, 1080/60i, 1080/50i
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50 - 60 Hz)
- 302 Watt
- 39.8 cm x 31 cm x 15.2 cm
- 4 kg
- 3-year warranty
- LCD projector
- Built-in Devices
- Speaker
Projector
- Brightness
- 3000 lumens
- Contrast Ratio
- 2000:1
- Image Size
- 152 cm - 279 cm
- Throw Ratio
- 0.47:1
- Resolution
- XGA - XGA (1024 x 768) (native) / 1680 x 1050 (resized)
- 4:3
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- 230 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- Eco-Mode technology, Color Management System, freeze frame, Micro Lens Array (MLA) Technology, JPEG photo playback, wall colour correction, Deep Color, DICOM Simulation Mode
Lens
- Focus Type
- Manual
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -20 / +20
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
Input Device
- External
- 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x HDMI , 1 x S-video input - 4 pin mini-DIN , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type B , 2 x USB 2.0 - 4 pin USB Type A
- Included Accessories
- Lens cover, wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection
- TUV GS, RoHS, GOST-R
- Voltage Required
- 302 Watt
- Power Consumption Operational (Standby)
- 0.4 Watt
- Software Included
- Drivers & Utilities
- 39.8 cm
- 31 cm
- 15.2 cm
- 4 kg
- Limited warranty - 3 years , Limited warranty - lamp - 6 months / 1000 hours
- 5 °C
- 40 °C
- 20 - 80%
- Sound Emission
- 35 dB
- Sound Emission (Economic Mode)
- 29 dB
