Get great performance while saving the environment. Advanced eco features help to substantially lower your operating cost without compromising on quality and flexibility. Less shadow and glare gives the presenter more space to engage with his audience and enhances the experience with interactive white boards. The M260XS is particularly suited for classrooms and small to medium sized meeting rooms.
It can get great performance while not compromising on quality and ease of use. -
Save the environment
It can save the environment with eco technology by minimizing your power consumption and consumables replacements. -
Large flexibility
It features large flexibility in positioning the projector and minimized cost for replacements. -
Intuitive use
It features intuitive use of eco and projection technology due to user-centric design. -
Wide format
Wide format allows you to enjoy extra space in presentations and other office files. -
Less shadow and glare - not standing in the light beam gives you more space to engage with your audience when presenting.
- NEC M260XS - LCD projector
- LCD projector
- Built-in Devices
- Speaker
- Brightness
- 2600 lumens
- Contrast Ratio
- 2000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Bulb type
- 185 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (NTSC, SECAM, PAL, PAL-M, NTSC 4.43, PAL 60)
- Digital Video Standard
- High-Definition Multimedia Interface (HDMI)
- Video Modes
- 480p, 720p, 480i, 576i, 576p, 1080/60i, 1080/50i
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 239 Watt
- 39.8 cm x 31 cm x 14 cm
- 4 kg
- 3-year warranty
- LCD projector
- Built-in Devices
- Speaker
Projector
- Brightness
- 2600 lumens
- Contrast Ratio
- 2000:1
- Image Size
- 152 cm - 279 cm
- Throw Ratio
- 0.47:1
- Resolution
- XGA - XGA (1024 x 768) (native) / 1920 x 1080 (resized)
- 4:3
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- 185 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction, aspect control
- Color Management System, freeze frame, Micro Lens Array (MLA) Technology, wall colour correction, Auto Vertical Keystone
Lens
- Focus Type
- Manual
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -20 / +20
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
Input Device
- External
- 2 x VGA input - 15 pin D-Sub (DB-15) , 1 x composite video input - RCA , 1 x HDMI input , 1 x S-video input - 4 pin mini-DIN , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type B , 2 x USB 2.0 - 4 pin USB Type A
- Included Accessories
- Lens cover, wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, control panel lock, security bar
- TUV GS, RoHS, GOST-R
- Voltage Required
- 239 Watt
- Power Consumption Operational (Standby)
- 0.4 Watt
- 39.8 cm
- 31 cm
- 14 cm
- 4 kg
- EMEA warranty - 3 years , EMEA warranty - lamp - 6 months / 1000 hours
- 5 °C
- 40 °C
- 20 - 80%
- Sound Emission
- 35 dB
- Sound Emission (Economic Mode)
- 29 dB
