Take your productivity to heights. With the 26" NEC MultiSync EA261WM, NEC has developed a desktop display that combines cutting-edge technologies with dynamic design accents, giving you the ability to increase your productivity while adding a modern flair to your desktop. This widescreen model, which touts flexibility for any number of applications and environments, meets the diverse needs of businesses of all kinds.
This display's wide-format screen provides roughly the same work area as two smaller-sized LCD screens, allowing you to work simultaneously in multiple/side-by-side application windows.
The EA261WM features swivel, tilt and pivot capabilities and a height-adjustable stand, allowing you to create an ideal ergonomic display orientation for maximum viewing comfort.
- NEC MultiSync EA261WM - LCD monitor - 26"
- LCD monitor - 26"
- Stereo speakers
- Native Resolution
- 1920 x 1200 at 60 Hz
- Pixel Pitch
- 0.292 mm
- Brightness
- 400 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- 59.4 cm x 27.2 cm x 45.1 cm
- 12.4 kg
- Microsoft Certification
- Certified for Windows Vista
- DDC-2B, ISO 13406-2, VESA DPMS, RoHS, WEEE
- Display Type
- LCD monitor / TFT active matrix
- Diagonal Size
- 26"
- Built-in Devices
- Stereo speakers
- Native Resolution
- Pixel Pitch
- 0.292 mm
- Brightness
- 400 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 76 Hz
- Horizontal Refresh Rate
- 81.1 kHz
- Horizontal Viewing Angle
- +80 / -80
- Vertical Viewing Angle
- +80 / -80
- Controls & Adjustments
- Brightness, contrast, colour temperature
- XtraView, AccuColor Control Systems, Rapid Response, No Touch Auto Adjust, Ambix, Dynamic Video Mode, NaViSet, Eco-Mode
- 12.4 kg
Audio
- Speakers - stereo
- 1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x DVI-D - 24+1 pin digital DVI
Mechanical
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), wall mountable, cable organizer
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 99 Watt
- Power Consumption Stand by / Sleep
- 2 Watt
- Included Software
- Drivers & Utilities, NaViSet
- 5 °C
- 35 °C
- 30 - 80%
