NEC EA243WM (White)  24 INCH TN panel  LED backlight. Native
Quicklinx: 7YKNWS00 Mfr#: 60003157
  • High-Definition Multimedia Interface (HDMI)
The 24" NEC MultiSync EA243WM, a widescreen desktop display boasting high-performance, advanced technologies and a full feature set, is ideal for corporate clients and digital signage users requiring HDMI connectivity in a small screen size. The LED backlighting of the EA243WM allows for a slimmer profile, lighter weight and increased power savings compared to previous generation models. It offers touch-sensitive controls that are integrated into the bezel, making display adjustments easier and more intuitive than ever. Smart sensing technology automatically detects your work conditions to determine the proper display brightness with ambient light and human sensors. A comprehensive input panel, including HDMI, DisplayPort, DVI-D and VGA, connects users to the latest peripherals and future-proofs the investment.
NEC MultiSync EA243WM - LED monitor - 24.1"
LED-backlit LCD monitor - 24.1"
Energy Class
Class B
USB 2.0 hub
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 25000:1 (dynamic)
Response Time
5 ms
Colour Support
16.8 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Voltage
White
55.6 cm x 23 cm x 40.9 cm
7 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Plug and Play, FCC Class B certified, CSA, UL, TUV GS, GOST, cUL, DDC-2B, MPR III, PCT, CCC, TUV Ergo, RoHS, ISO 9241-307, GEEA, ErP Ready
3-year warranty
Display Type
Energy Class
Class B
Diagonal Size
24.1"
Built-in Devices
USB 2.0 hub
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.27 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
60 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, colour temperature
Infrared user sensor, ambient light sensor, No Touch Auto Adjust, Intelligent Power Manager (IPM), power off timer, sRGB colour management, HDCP, Eco-Mode, ControlSync
White
7 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
VGA , DVI-D , HDMI , DisplayPort , USB 2.0 upstream (Type B) , 4 x USB 2.0 downstream , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+30
Swivel Angle
340
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management
1 x VGA cable - VGA to VGA , 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x USB cable
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
29 Watt
Power Consumption Stand by / Sleep
0.5 Watt
Included Software
Drivers & Utilities
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - backlight - 3 years
5 °C
35 °C
20 - 80%
