The NEC MultiSync E905 succeeds in balancing impressive visual performance with a budget-oriented large format presentation without compromise. The 90 inch (229 cm) LCD-panel features a detail-rich Full HD resolution, eye-pleasing black levels for ergonomic viewing and exciting connectivity optimized to the needs of corporate applications. Thanks to an integrated ambient light sensor and LED backlight technology, the model features an amazingly low TCO with maintenance-free operation.
This display is ideal for corporate conferencing and education usage as well as digital signage applications in museums, hospitality and retail environments with operating hours limited to 12/7.
Programmable ambient light sensor
It is used for reduced power consumption and eye pleasing brightness levels. -
Future ready connectivity
It features multiple industry standard digital and analog signal inputs for flexible integration into AV infrastructures. -
Slim design and integrated speakers
The aesthetic design is pleasing to the eye and enables easy, low cost installation. -
Reduced installation and operating costs
This product features LED backlight technology the display is highly energy efficient with a low power consumption, longer backlight lifetime and a lighter design for easy and flexible transportation, mounting and integration. -
Impressive Full HD LCD technology
It provides eye-pleasing black levels and impressive contrast ratios for ergonomic viewing and less fatigue in conferencing scenarios. -
Special characteristics
This display has plenty of features as automatic alarm e-mails, color temperature mode, image flip, NaViSet administrator 2, point zoom function, scheduler, ambient light sensor, carbon savings meter, ECO mode.
- NEC MultiSync E905 E Series - 90" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 90"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Input Video Formats
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- UV²A
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control, NaViSet Administrator 2
- Energy Class
- Class A
- 270 Watt
- Power Consumption (On mode)
- 266 W
- Power Consumption Stand by
- 1 Watt
- Energy Consumption per Year
- 388 kWh
- Dimensions (WxDxH) - without stand
- 205.8 cm x 12.3 cm x 118.4 cm
- 81 kg
- 3-year warranty
- Product Type
- Energy Class
- Class A
- 270 Watt
- 266 W
- 388 kWh
- Diagonal Class
- 90"
- Commercial Use
- Series
- E Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS)
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- HDCP Compatible
- Modes
- Landscape mode, Eco mode
- Dimensions
- Without stand
- 205.8 cm
- 12.3 cm
- 118.4 cm
- 81 kg
Display
- LCD Display Technology
- UV²A
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- Direct-lit LED
- Image Contrast Ratio
- 5000:1
- Brightness
- 350 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 4 ms
- Carbon Footprint Meter, automatic alarm e-mails, Point Zoom function
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 400 x 400 mm
Video Features
- Supported Computer Resolutions
- 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- External Speakers Amplifier Power (Total)
- 30 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- HDMI - rear , USB , Serial input , 2 x audio input , VGA input , DisplayPort input , DVI-D input , HDMI input - side , LAN , Audio output , Speakers output
- NaViSet Administrator 2
- Cables Included
- DVI cable
- FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, VESA DPMS, PSB, RoHS
- Power Device
- Power supply
- 1 Watt
- Power Consumption Sleep
- 0.5 Watt
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
- 0 °C
- 40 °C
- 20 - 80%
