The NEC MultiSync E505 succeeds in balancing impressive visual performance with a budget-oriented large format presentation without compromise. The model captures attention via eye-pleasing image quality for ergonomic viewing and versatile digital connectivity optimized to the needs of corporate and signage applications.
Thanks to LED backlight technology, the display features an amazingly low TCO. Packed with integrated features like USB media player, speakers and scheduling function, E-Series models are also qualified for standalone applications in public environments.
This display is ideal for corporate conferencing and education usage as well as digital signage applications in museums, hospitality and retail environments with operating hours limited to 12/ 7.
- NEC MultiSync E505 E Series - 50" LED-backlit LCD display - Full HD - for digital signage / hospitality
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 50"
- Commercial Use
- Yes - digital signage / hospitality
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Input Video Formats
- 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/60p, 1080/30p, 480/60i
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15)
- Technology
- S-PVA
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control, 2 AAA batteries
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class A
- 124 Watt
- Power Consumption (On mode)
- 87 W
- Energy Consumption per Year
- 127 kWh
- Dimensions (WxDxH) - without stand
- 112.36 cm x 7.7 cm x 64.67 cm
- 12.62 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Product Type
- Energy Class
- Class A
- 124 Watt
- 87 W
- 127 kWh
- Diagonal Class
- 50"
- Commercial Use
- Series
- E Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15)
- Modes
- Landscape mode
- Dimensions
- Without stand
- 112.36 cm
- 7.7 cm
- 64.67 cm
- 12.62 kg
Display
- LCD Display Technology
- S-PVA
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- Direct-lit LED
- Image Contrast Ratio
- 5000:1
- Brightness
- 300 cd/m²
- Viewing Angle
- 176 degrees
- Viewing Angle (Vertical)
- 176 degrees
- Response Time
- 8 ms
- Colour Temperature Control
- Scheduler Function (with RTC)
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 400 x 200 mm
Video Features
- Supported Computer Resolutions
- 1366 x 768, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 720, 720 x 400, 1920 x 1080, 1280 x 800
Media Player
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Audio Controls
- Equalizer
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- 3 x HDMI - side , USB - side , Serial input - side , Composite video / component video input - rear , Audio input - rear , VGA input - rear , Audio input - rear , SPDIF output - rear
- 2 AAA batteries
- Cables Included
- VGA cable
- FCC Class B certified, CSA, UL, C-Tick, cUL, DDC-2B, SASO, VESA DPMS, PSB, REACH
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- Input Voltage
- Power Consumption Sleep
- 0.5 Watt
- On / Off Switch
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel with stand - 112.36 cm x 25.5 cm x 68.37 cm x 13.12 kg , Panel without stand - 112.36 cm x 7.7 cm x 64.67 cm x 12.62 kg
- 0 °C
- 40 °C
- 20 - 80%
