NEC AccuSync AS241W 24" 1920x1080 DVI LED Monitor
Quicklinx: 993DWS00 Mfr#: 60003295
24" 16:9 Wide LCD with TN TFT Display features green product design using the latest LED backlight technology at an affordable price. The attractively designed display comes also with DVI-D input. It is the ideal monitor for entry-level, corporate and demanding consumers.
  • Energy efficient
    With an ENERGY STAR certification and an energy consumption of only 22 kWh per year, this display is designed for eco-conscious users looking to reduce their carbon footprint and electricity bills.
  • Vivid visuals
    Experience true-to-life colors with 16.7 million color support and a high contrast ratio of 1000:1, ensuring deep blacks and bright whites. The Full HD 1920 x 1080 resolution delivers crisp, clear images for an immersive viewing experience.
  • Adjustable comfort
    The display's tilt adjustment feature allows you to find the perfect viewing angle, enhancing comfort during long periods of use. This ergonomic design ensures a more enjoyable and productive workspace.
  • Seamless connectivity
    Equipped with both DVI and VGA interfaces, this monitor offers versatile connectivity options, allowing for easy setup and integration with a wide range of devices.
NEC AccuSync AS241W - LCD monitor - Full HD (1080p) - 24"
LCD monitor - 24"
Energy Class
Class A+
Energy Consumption per Year
22 kWh
Power Consumption (On mode)
15 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.272 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Voltage
56.6 cm x 19 cm x 39.5 cm
4.3 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, CSA, UL, TUV GS, GOST, cUL, DDC-2B, DDC-2Bi, PCT, CCC, TUV Ergo, ISO 9241-307, GEEA, ERP
3-year warranty
Display Type
LCD monitor / TFT active matrix
Energy Class
Class A+
22 kWh
Diagonal Size
24"
Viewable Size
23.55"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.272 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Vertical Refresh Rate
76 Hz
Horizontal Refresh Rate
81.1 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
170
Backlight Technology
CCFL
Controls & Adjustments
Brightness, contrast, colour balance, colour temperature
Rapid Response, Eco-Mode
56.6 cm x 19 cm x 39.5 cm - with stand
4.3 kg
VGA , DVI-D
Mechanical
Tilt
Tilt Angle
22
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), cable organizer
1 x VGA cable
Input Voltage
15 W
Power Consumption (Typical)
23 Watt
Power Consumption Stand by / Sleep
0.45 Watt
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
5 °C
35 °C
20 - 80%
