24" 16:9 Wide LCD with TN TFT Display features green product design using the latest LED backlight technology at an affordable price. The attractively designed display comes also with DVI-D input. It is the ideal monitor for entry-level, corporate and demanding consumers.
Energy efficient
With an ENERGY STAR certification and an energy consumption of only 22 kWh per year, this display is designed for eco-conscious users looking to reduce their carbon footprint and electricity bills. -
Vivid visuals
Experience true-to-life colors with 16.7 million color support and a high contrast ratio of 1000:1, ensuring deep blacks and bright whites. The Full HD 1920 x 1080 resolution delivers crisp, clear images for an immersive viewing experience. -
Adjustable comfort
The display's tilt adjustment feature allows you to find the perfect viewing angle, enhancing comfort during long periods of use. This ergonomic design ensures a more enjoyable and productive workspace. -
Seamless connectivity
Equipped with both DVI and VGA interfaces, this monitor offers versatile connectivity options, allowing for easy setup and integration with a wide range of devices.
- NEC AccuSync AS241W - LCD monitor - Full HD (1080p) - 24"
- LCD monitor - 24"
- Energy Class
- Class A+
- Energy Consumption per Year
- 22 kWh
- Power Consumption (On mode)
- 15 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.272 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 56.6 cm x 19 cm x 39.5 cm
- 4.3 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, CSA, UL, TUV GS, GOST, cUL, DDC-2B, DDC-2Bi, PCT, CCC, TUV Ergo, ISO 9241-307, GEEA, ERP
- 3-year warranty
- Display Type
- LCD monitor / TFT active matrix
- Energy Class
- Class A+
- 22 kWh
- Diagonal Size
- 24"
- Viewable Size
- 23.55"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.272 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 76 Hz
- Horizontal Refresh Rate
- 81.1 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 170
- Backlight Technology
- CCFL
- Controls & Adjustments
- Brightness, contrast, colour balance, colour temperature
- Rapid Response, Eco-Mode
- Black
- 56.6 cm x 19 cm x 39.5 cm - with stand
- 4.3 kg
- VGA , DVI-D
Mechanical
- Tilt
- Tilt Angle
- 22
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), cable organizer
- Cables Included
- 1 x VGA cable
- Input Voltage
- 15 W
- Power Consumption (Typical)
- 23 Watt
- Power Consumption Stand by / Sleep
- 0.45 Watt
- ENERGY STAR Certified
- Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
- 5 °C
- 35 °C
- 20 - 80%
