21.5" 16:9 wide LCD with TN TFT display features green product design using the latest LED backlight technology at an affordable price. The attractively designed display comes with VGA and DVI-D input. The ideal monitor is for entry-level, corporate and demanding consumers.
- NEC AccuSync AS222WM - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Class
- Class A
- Energy Consumption per Year
- 26 kWh
- Power Consumption (On mode)
- 18 W
- Panel Type
- TN
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Speakers
- Integrated
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 50.74 cm x 20.51 cm x 36.47 cm
- 4.1 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, CSA, UL, TUV GS, GOST, cUL, DDC-2B, DDC-2Bi, PCT, VESA EDID, TUV Ergo, ISO 9241-307, ERP
- 3-year warranty
- Display Type
- Energy Class
- Class A
- 26 kWh
- Diagonal Size
- 21.5"
- Panel Type
- TN
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 31.5 - 81.1 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- WLED
- Controls & Adjustments
- Tilt
- Rapid Response, HDCP, Eco-Mode, OSD lock, Carbon Savings Meter
- Black
- 4.1 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1 Watt
- DVI-D (HDCP) , VGA
Mechanical
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), cable organizer
- Cables Included
- 1 x VGA cable
- Power Supply
- Internal
- Input Voltage
- 18 W
- Power Consumption (Typical)
- 27 Watt
- Power Consumption Stand by
- 0.35 Watt
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
- 5 °C
- 35 °C
- 20 - 80%
