NEC 5000 ANSI Lumens WUXGA projector - 7.8kg (PA500U)
Quicklinx: 7N7NWS00 Mfr#: 60003082
  • High-Definition Multimedia Interface (HDMI)
A top performer for multiple business applications, the highest resolution paired with brightness, best installation flexibility and excellent connectivity. The PA500U's special inorganic panels provide for longer operation times and less service cost.
Type LCD
Brightness [ANSI Lumen] 5000
Contrast 2000:1
Resolution 1920 x 1200
Lamp Life [h] 3000
Distance [m] 0.5 - 76.4
Weight [kg] 7.8
  • Great picture quality
    Even in bright ambient light because of high projector brightness and excellent HQV signal processing.
  • Low installation cost
    With high installation flexibility because of 2x wide zoom lens, lens shift, 360° tilt installation and lens centered design. Replace old installation projectors with minimal reinstallation cost.
  • Quick and easy network connection
    Included many network features for picture transfer and complete cost saving network control by using network technology. This technology is also great for PC-less presentation directly from network or from USB memory.
  • Enjoy low tco
    By using state of the art technology, inorganic panels thus save the environment and cost by minimizing power consumption, consumables and also service frequency.
  • Best brightness flexibility
    By using PA's built-in stacking or edge blending features, when used in combination with other PA projectors. Achieve brightness as high as 20,000 ANSI lumen or extremely large pictures within some minutes with NEC automatic stacking setup application included free of charge.
NEC PA500U - LCD projector - no lens - 3D
LCD projector - 1080p
3D Capable
Built-in Devices
Speaker
European Union
Brightness
5000 lumens
Contrast Ratio
2000:1
Resolution
WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Lens
No lens
Lens Shift Direction
Horizontal, vertical
Bulb type
330 Watt
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
Digital Video Standard
High-Definition Multimedia Interface (HDMI), DisplayPort
Video Modes
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 576/50i, 480/50i
Speakers
Speaker(s) - integrated
AC 120/230 V (50 - 60 Hz)
455 Watt
49.9 cm x 35.9 cm x 14.4 cm
7.8 kg
3-year warranty
3D Capable
Built-in Devices
Speaker
European Union
Projector
Brightness
5000 lumens
Contrast Ratio
2000:1
Image Size
76 cm - 1270 cm
Resolution
WUXGA - WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Max Sync Rate (V x H)
120 Hz x 108 kHz
Bulb type
330 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
Eco-Mode technology, 3D Reform technology, Micro Lens Array (MLA) Technology, Edge blending, High-bandwidth Digital Content Protection System (HDCP), wall colour correction, USB host function, Hollywood Quality Video (HQV), Crestron RoomView, Geometric Adjustment, Intelligent Power Management, DICOM Simulation Mode, AMX Device Discovery, Direct Power Off
Lens
No lens
Focus Type
Manual
Zoom Type
Manual
Keystone Correction Direction
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, DisplayPort, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
Input Device
External
2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 5 x component video / RGB input - BNC , 1 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x DisplayPort - 20 pin DisplayPort , 1 x S-video input - 4 pin mini-DIN , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 3 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x serial RS-232 , 1 x management - RJ-45 , 2 x USB 2.0 - 4 pin USB Type A , 1 x audio line-out - mini-phone stereo 3.5 mm
Wireless remote control
1 x VGA cable
Security Features
Password protection
TUV GS, RoHS, ErP Ready
455 Watt
Power Consumption Operational (Standby)
0.2 Watt
49.9 cm
35.9 cm
14.4 cm
7.8 kg
Limited warranty - 3 years , Limited warranty - lamp - 6 months / 1000 hours
5 °C
20 - 80% (non-condensing)
Sound Emission
38 dB
32 dB
