NEC 46" Widescreen LCD Display
Quicklinx: 69TLWS00 Mfr#: 60002633
With its high-bright, professional-grade panel and remarkable contrast ratio (3500:1), the 46" NEC MultiSync X461HB displays images at amazing brightness levels no matter the lighting condition. Ideal for environments heavy with ambient light, this model boasts 110% higher brightness than NEC's previous-generation displays while consuming only 50% more power. The result is an image that outperforms that of displays with standard brightness, which can appear dim or washed out when placed in areas with high ambient light. The X461HB's unrivaled screen performance is enhanced by 30+ advanced features of the digital signage technology suite, including advanced thermal protection.
  • Thermal protection
    It starts with an extra thermal layer on the display panel to diffuse heat followed by fan-based technology specially designed to work in both landscape and portrait modes and be controlled locally or remotely.
  • Built-in expansion slot
    Built-in expansion slot future-proofs your display investment, allowing for seamless integration of NEC and third-party components, including an HD-SDI card, single-board computer and DVI daisy chain capability.
  • Sealed panel design
    It provides protection in less than optimal environments, while protecting against particles like dust, grease, or steam from getting behind the glass and damaging the unit.
  • Ambient light sensor
    Automatically adjusts the backlight and power management depending on the ambient lighting brightness.
  • Multi-display control and daisy chain
    Enabled through RS-232, allows for individually addressable display control, making setup and monitoring of the display simple and effective.
  • Ethernet Control and Communication
    Provides the highest level of remote display management and includes such features as automatic email notification for diagnostic purposes.
  • Carbon footprint meter
    Informs and motivates responsible use of the display by calculating and tracking carbon savings.
  • Improved auto-detection scheme
    Improved auto-detection scheme allows for user customization of input selection.
  • Quick input change
    Quick input change speeds up transitions from one input mode to another.
  • Real-time clock/round-the-clock scheduling
    It allows for advanced scheduling of monitor powering up/down and input selection. These features also allow your messaging to be customized for time of day as well as improving energy savings and extending display life.
  • Advanced screen saver functions
    These include an array of features designed to reduce the risk of image persistence and extend display life. A gamma adjustment feature reduces the effect of high-contrast images, while a side color function allows adjustment of the color to minimize the contrast delta.
  • CableComp+
    This technology uses a digitized signal delay circuit to automatically compensate for each red, green and blue cable's length and video signal delay, ensuring sharp image reproduction.
NEC MultiSync X461HB 46" LCD flat panel display - HD
Diagonal Class
46"
Resolution
1360 x 768
Display Format
720p
Input Video Formats
480p, 480i, 576i, 576p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p
Max Number of Screens
100
Video Interface
Component, composite, HDMI, S-Video
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
S-PVA
Image Aspect Ratio
16:9
TV Tuner
No tuner
Picture Enhancements
XtraView+
Sound Output Mode
Stereo
Speaker System
Speakers not included
Remote control
Microsoft Certification
Certified for Windows Vista
Voltage
Energy Class
Class G
320 Watt
106 cm x 14 cm x 60.9 cm
31 kg
3-year warranty
Energy Class
Class G
320 Watt
Diagonal Class
46"
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Ambient light sensor (ALS), temperature sensor
Video Interface
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Modes
Portrait mode
XtraView+
Timer Functions
Countdown
Dimensions
Without stand
106 cm
14 cm
60.9 cm
31 kg
Enclosure Colour
Display
LCD Display Technology
S-PVA
Resolution
1360 x 768
Display Format
720p
Image Aspect Ratio
16:9
Colour Depth
16.7 million colours
Image Contrast Ratio
3500:1
Brightness
1500 cd/m²
Widescreen Modes
16:9
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.7455 x 0.7455mm
Response Time
8 ms
V-Sync Rate at Max Res.
60 Hz
Max V-Sync Rate
85 Hz
Max H-Sync Rate
91.1 kHz
Eco TV, AmbiBright, AutoBright Technology, NaViSet, Scheduler Function (with RTC), TileMatrix (10 x 10), Digital Signage Technology Suite (DSTS), Rapid Response technology, CableComp, TileComp, TileMatrix
Video Wall
100
Stands & Mounts
Flat Panel Mount Interface
300 x 300 mm
Video Features
16:9 Mode
Analogue Video Input Signals
NTSC, PAL, SECAM
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1440 x 1050, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 832 x 624, 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 720 x 400, 1680 x 1050 (WSXGA+), 1920 x 1080
Remote Control
Remote control
Audio System
Sound Output Mode
Stereo
Speaker System
External Speakers Amplifier Power (Total)
30 Watt
Connector Type
RGB input , RGB output , HDMI , DVI-Digital , VGA input , Component video input , Composite video output , Composite video input , S-Video input , Composite video input , 2 x audio line-in , Audio line-in , Audio line-out , 2 x serial , LAN , 4 x speakers output
Expansion Slots
1 x Expansion Slot
VGA cable
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, DDC-2B, DDC-2Bi, VESA DPMS, CCC, PSB, DDC/CI
Power supply - internal
Input Voltage
Power Consumption Stand by / Sleep
1 Watt
On/off timer, energy save
Limited warranty - 3 years
Dimensions & Weight Details
Panel with stand - 106 cm x 35.1 cm x 64.5 cm x 32.9 kg
