NEC 46" LCD Display
NEC 46" LCD Display
Quicklinx: 69TKWS00 Mfr#: 60002632
The 46" NEC MultiSync X461UN is about to revolutionize how LCD video walls are perceived. Its ultra-narrow bezel allows for a screen-to-screen distance between two neighboring displays of only 7.3mm, a near 450% improvement from NEC's previously revolutionary 33mm MultiSync 20 series displays. The display, which is ideal for digital signage and broadcast applications, can be deployed in video wall matrices of up to 10 x 10 (100 displays), creating a total surface area of approximately 645 sq ft. The barely discernable transition gap between displays ensures a homogenous picture across the matrix.
NEC MultiSync X461UN 46" LCD flat panel display - HD
Diagonal Class
46"
Resolution
1360 x 768
Display Format
720p
Input Video Formats
480p, 480i, 576i, 576p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p
Video Interface
Component, composite, HDMI, S-Video
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
S-PVA
Image Aspect Ratio
16:9
TV Tuner
No tuner
Sound Output Mode
Stereo
Speaker System
Speakers not included
Remote control
Microsoft Certification
Certified for Windows Vista
Voltage
200 Watt
103 cm x 12.8 cm x 58 cm
29 kg
3-year warranty
200 Watt
Diagonal Class
46"
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Ambient light sensor (ALS), temperature sensor
Video Interface
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Modes
Portrait mode
Timer Functions
Countdown
Dimensions
Without stand
103 cm
12.8 cm
58 cm
29 kg
Enclosure Colour
Display
LCD Display Technology
S-PVA
Resolution
1360 x 768
Display Format
720p
Image Aspect Ratio
16:9
Colour Depth
16.7 million colours
Image Contrast Ratio
3000:1
Brightness
700 cd/m²
Widescreen Modes
16:9
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.746 x 0.746mm
Response Time
8 ms
V-Sync Rate at Max Res.
60 Hz
Max V-Sync Rate
85 Hz
Max H-Sync Rate
91.1 kHz
TileMatrix (10 x 10), Rapid Response technology, TileComp, TileMatrix
Stands & Mounts
Flat Panel Mount Interface
300 x 300 mm
Video Features
16:9 Mode
Analogue Video Input Signals
NTSC, PAL, SECAM
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1440 x 1050, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 832 x 624, 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 720 x 400, 1680 x 1050 (WSXGA+), 1920 x 1080
Remote Control
Remote control
Audio System
Sound Output Mode
Stereo
Speaker System
External Speakers Amplifier Power (Total)
30 Watt
Connector Type
RGB input , RGB output , HDMI , DVI-Digital , VGA input , Component video input , Composite video output , Composite video input , S-Video input , Composite video input , 2 x audio line-in , Audio line-in , Audio line-out , 2 x serial , LAN
Expansion Slots
1 x Expansion Slot
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, DDC-2B, DDC-2Bi, VESA DPMS, CCC, PSB, DDC/CI
Power supply - internal
Input Voltage
Power Consumption Stand by / Sleep
1 Watt
On/off timer, energy save
Limited warranty - 3 years
Dimensions & Weight Details
Panel with stand - 103 cm x 35.1 cm x 62.4 cm x 30.8 kg
