NEC's 46" X464UNS sets the standard for rugged 24/7 use in the harshest installation environments. LED edge lighting delivers environmental, economic, and aesthetic impact. With a decreased total cost of ownership, an upgraded cabinet, and customizable connectivity options, the X464UNS delivers stunning solutions.
- NEC MultiSync X464UNS X Series - 46" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 46"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Input Video Formats
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Frame Rate & Enhancement Technology
- 60 Hz Refresh Rate
- Video Interface
- Component, HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- S-PVA
- LCD Backlight Technology
- WLED backlight - direct-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- Speakers not included
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- 255 Watt
- Power Consumption (On mode)
- 110 W
- Power Consumption Stand by
- 1 Watt
- Energy Consumption per Year
- 160 kWh
- Dimensions (WxDxH) - without stand
- 102.2 cm x 10.13 cm x 57.66 cm
- 20.4 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Product Type
- Energy Class
- Class B
- 255 Watt
- 110 W
- 160 kWh
- Diagonal Class
- 46"
- Commercial Use
- Series
- X Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS), temperature sensor, NFC sensor
- Video Interface
- Component, HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- HDCP Compatible
- Modes
- Eco mode
- Dimensions
- Without stand
- 102.2 cm
- 10.13 cm
- 57.66 cm
- 20.4 kg
Display
- LCD Display Technology
- S-PVA
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- Image Contrast Ratio
- 3500:1
- Brightness
- 700 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- TileMatrix, Open Pluggable Specification slot, Carbon Footprint Meter, automatic alarm e-mails, Frame Comp, HTTP server, Point Zoom function
Stands & Mounts
- Flat Panel Mount Interface
- 300 x 300 mm
Video Features
- Supported Computer Resolutions
- 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 3840 x 2160, 4096 x 2160
Audio System
- Speaker System
- External Speakers Amplifier Power (Total)
- 30 Watt
- Connector Type
- DVI-D input , HDMI , 2 x DisplayPort input , VGA / component video input , Remote control input , Serial input , 2 x audio input , 2 x LAN , USB , Audio output , Speakers output
- FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, VESA DPMS, VESA FDMI, PSB, RoHS
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- Input Voltage
- 1 Watt
- Power Consumption Sleep
- 0.5 Watt
- On / Off Switch
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
- 0 °C
- 40 °C
- 20 - 80%
