NEC 46" 1920 x 1080 DVI HDMI DisplayPort LCD Display
Quicklinx: CBX3WS00 Mfr#: 60003722
  • 1080p
NEC's 46" X464UNS sets the standard for rugged 24/7 use in the harshest installation environments. LED edge lighting delivers environmental, economic, and aesthetic impact. With a decreased total cost of ownership, an upgraded cabinet, and customizable connectivity options, the X464UNS delivers stunning solutions.
  • Enhanced visibility
    With a brightness of 700 cd/m2, the NEC MultiSync X464UNS ensures your content is vivid and engaging in various lighting conditions, making it ideal for public displays and professional settings.
  • Crisp, clear images
    The 46-inch display offers a Full HD resolution with a 3500:1 image contrast ratio, delivering sharp, detailed images and deep blacks. Coupled with direct-lit LED technology, it provides consistent illumination across the screen.
  • Versatile connectivity
    Equipped with HDMI, DVI-D, and DisplayPort inputs, this display supports a wide range of devices, making it easy to connect to PCs, media players, and other digital sources.
  • Efficient design
    ENERGY STAR certification signifies that the NEC MultiSync X464UNS is not only energy efficient but also designed to reduce its carbon footprint, aligning with your sustainability goals.
  • Wide viewing angles
    Featuring S-PVA LCD display technology, it offers wide viewing angles up to 178°, ensuring your content is easily visible from almost any viewpoint without color distortion.
NEC MultiSync X464UNS X Series - 46" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
46"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Input Video Formats
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Frame Rate & Enhancement Technology
60 Hz Refresh Rate
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
S-PVA
LCD Backlight Technology
WLED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
Speakers not included
Voltage
Energy Class
Class B
255 Watt
Power Consumption (On mode)
110 W
Power Consumption Stand by
1 Watt
Energy Consumption per Year
160 kWh
102.2 cm x 10.13 cm x 57.66 cm
20.4 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Energy Class
Class B
255 Watt
110 W
160 kWh
Diagonal Class
46"
Commercial Use
Series
X Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Ambient light sensor (ALS), temperature sensor, NFC sensor
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Eco mode
Dimensions
Without stand
102.2 cm
10.13 cm
57.66 cm
20.4 kg
Display
LCD Display Technology
S-PVA
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
60 Hz Refresh Rate
Image Contrast Ratio
3500:1
Brightness
700 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
TileMatrix, Open Pluggable Specification slot, Carbon Footprint Meter, automatic alarm e-mails, Frame Comp, HTTP server, Point Zoom function
Stands & Mounts
Flat Panel Mount Interface
300 x 300 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 3840 x 2160, 4096 x 2160
Audio System
Speaker System
External Speakers Amplifier Power (Total)
30 Watt
Connector Type
DVI-D input , HDMI , 2 x DisplayPort input , VGA / component video input , Remote control input , Serial input , 2 x audio input , 2 x LAN , USB , Audio output , Speakers output
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, VESA DPMS, VESA FDMI, PSB, RoHS
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Input Voltage
1 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
Limited warranty - 3 years , Limited warranty - backlight - 3 years
20 - 80%
