NEC 4200 ANSI Lumen XGA Projector - 3.9kg (P420X)
Quicklinx: 7N7BWS00 Mfr#: 60003081
  • High-Definition Multimedia Interface (HDMI)
Get great picture performance paired with outstanding network features. Advanced Eco features help to lower your operating and service cost. Because of high brightness and excellent installation flexibility the P420X is the best solution for larger meeting rooms and University lecture halls.
Type LCD
Brightness [ANSI Lumen] 4200
Contrast 2000:1
Resolution 1024 x 768
Lamp Life [h] 3000
Distance [m] 0.7 - 11
Weight [kg]
NEC P420X - LCD projector - 3D - LAN
LCD projector
3D Capable
Built-in Devices
Speaker
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Brightness
4200 lumens
Contrast Ratio
2000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Lens Shift Direction
Vertical
Bulb type
265 Watt
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 3500 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60), LAN
Digital Video Standard
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - internal
343 Watt
31 cm x 28.9 cm x 12.5 cm
3.9 kg
3-year warranty
LCD projector
3D Capable
Built-in Devices
Speaker
802.11b/g/n, Ethernet
Projector
Brightness
4200 lumens
Contrast Ratio
2000:1
Image Size
53 cm - 762 cm
Projection Distance
0.7 m - 11 m
Throw Ratio
1.3 - 2.2:1
Resolution
XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
4:3
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
265 Watt
Bulb life cycle
Eco-Mode technology, AutoSense technology, Advanced AccuBlend technology, VORTEX Technology Plus, 3D Reform technology, Micro Lens Array (MLA) Technology, wall colour correction, Auto Vertical Keystone, DICOM Simulation Mode, AMX Device Discovery
Lens
Focus Type
Manual
Lens Aperture
F/1.7-2.07
Zoom Type
Manual
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Vertical
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Internal
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 2 x audio line-in - mini-phone 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x USB - 4 pin USB Type B (management) , 1 x USB - 4 pin USB Type A , 1 x network - RJ-45 (management)
Wireless / wired remote control
1 x VGA cable
Security Features
TUV GS, RoHS, EuP Ready
343 Watt
Power Consumption Operational (Standby)
0.4 Watt
31 cm
28.9 cm
12.5 cm
3.9 kg
Limited warranty - 3 years , Limited warranty - lamp - 6 months / 1000 hours
Sound Emission
36 dB
30 dB
