Get great picture performance paired with outstanding network features. Advanced Eco features help to lower your operating and service cost. Because of high brightness and excellent installation flexibility the P420X is the best solution for larger meeting rooms and University lecture halls.
Type LCD
Brightness [ANSI Lumen] 4200
Contrast 2000:1
Resolution 1024 x 768
Lamp Life [h] 3000
Distance [m] 0.7 - 11
Weight [kg]
- NEC P420X - LCD projector - 3D - LAN
- LCD projector
- 3D Capable
- Built-in Devices
- Speaker
- Networking
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Brightness
- 4200 lumens
- Contrast Ratio
- 2000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Lens Shift Direction
- Vertical
- Bulb type
- 265 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 3500 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60), LAN
- Digital Video Standard
- High-Definition Multimedia Interface (HDMI)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - internal
- Power
- AC 120/230 V (50/60 Hz)
- 343 Watt
- 31 cm x 28.9 cm x 12.5 cm
- 3.9 kg
- 3-year warranty
- LCD projector
- 3D Capable
- Built-in Devices
- Speaker
- Networking
- 802.11b/g/n, Ethernet
- Data Link Protocol
Projector
- Brightness
- 4200 lumens
- Contrast Ratio
- 2000:1
- Image Size
- 53 cm - 762 cm
- Projection Distance
- 0.7 m - 11 m
- Throw Ratio
- 1.3 - 2.2:1
- Resolution
- XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
- 4:3
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- 265 Watt
- Bulb life cycle
- Eco-Mode technology, AutoSense technology, Advanced AccuBlend technology, VORTEX Technology Plus, 3D Reform technology, Micro Lens Array (MLA) Technology, wall colour correction, Auto Vertical Keystone, DICOM Simulation Mode, AMX Device Discovery
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.7-2.07
- Zoom Type
- Manual
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -30 / +30
- Vertical
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Internal
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
- 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 2 x audio line-in - mini-phone 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x USB - 4 pin USB Type B (management) , 1 x USB - 4 pin USB Type A , 1 x network - RJ-45 (management)
- Included Accessories
- Wireless / wired remote control
- Cables Included
- 1 x VGA cable
- Security Features
- TUV GS, RoHS, EuP Ready
- Voltage Required
- 343 Watt
- Power Consumption Operational (Standby)
- 0.4 Watt
- 31 cm
- 28.9 cm
- 12.5 cm
- 3.9 kg
- Limited warranty - 3 years , Limited warranty - lamp - 6 months / 1000 hours
- Sound Emission
- 36 dB
- Sound Emission (Economic Mode)
- 30 dB
