NEC 40" 1920X1080 HD SILVER
Quicklinx: 7227WS00 Mfr#: 60002714
  • 1080p
Marketing description is not available.
NEC MULTEOS M401 40" LCD flat panel display - Full HD
Diagonal Class
40"
Silver black
Resolution
1920 x 1080
Display Format
1080p
Input Video Formats
480p, 480i, 576i, 576p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p
Video Interface
Component, composite, HDMI, S-Video
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), HDMI, DisplayPort
HDCP Compatible
PVA
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
Speakers not included
Remote control, remote control
Microsoft Certification
Certified for Windows Vista
Voltage
300 Watt
98.18 cm x 14.25 cm x 58.24 cm
25 kg
3-year warranty
300 Watt
Diagonal Class
40"
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Ambient light sensor (ALS)
Video Interface
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Dimensions
Without stand
98.18 cm
14.25 cm
58.24 cm
25 kg
Enclosure Colour
Silver black
Display
LCD Display Technology
PVA
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
Colour Depth
16.7 million colours
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.641mm
Response Time
8 ms
V-Sync Rate at Max Res.
60 Hz
Max H-Sync Rate
91.1 kHz
Stands & Mounts
Flat Panel Mount Interface
300 x 300 mm
Video Features
Analogue Video Input Signals
NTSC, PAL, SECAM
Input Video Formats
Supported Computer Resolutions
1440 x 1050, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 720 x 400, 1360 x 768, 1680 x 1050 (WSXGA+), 832 x 634
Remote Control
Remote control
Audio System
Speaker System
Output Power / Total
30 Watt
Connector Type
S-Video input , Composite video / component video input , VGA input , DVI-Digital , HDMI , DisplayPort , Composite video output , RGB output , 2 x audio line-in , Audio line-in , Audio line-out , 2 x serial , LAN
Remote control
VGA cable
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, VESA DPMS, CCC, PSB, RoHS
Power supply - internal
Input Voltage
Limited warranty - 3 years
Dimensions & Weight Details
Panel without stand - 98.18 cm x 14.25 cm x 58.24 cm x 25 kg , Panel with stand - 98.18 cm x 40 cm x 62.84 cm x 28.4 kg
