Get the Ultimate 3D Experience with a 3D ready DLP ®Projector from NEC. DLP®-Link™ technology allows 3D images to be projected with the aid of a single projector and active glasses without special screens, filters or emitters. The impression of 3D is created by the interaction with the active LCD shutter glasses. The easy to set up alternative to traditional 3D stereo projection.
Type DLP
Brightness [ANSI Lumen] 2600
Contrast 2000:1
Resolution 1280 x 800
Lamp Life [h] 3000
Distance [m] 1.2 - 13
Weight [kg] 2.5
- NEC V260W - DLP projector - portable - 3D
- DLP projector - 720p
- 3D Capable
- Built-in Devices
- Speaker
- Brightness
- 2600 lumens
- Contrast Ratio
- 2000:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Bulb type
- 180 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 5000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
- Digital Video Standard
- High-Definition Multimedia Interface (HDMI)
- Speakers
- Speaker(s) - internal
- Power
- AC 120/230 V (50 - 60 Hz)
- 233 Watt
- 31 cm x 9.5 cm x 24.7 cm
- 2.5 kg
- 3-year warranty
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Brightness
- 2600 lumens
- Contrast Ratio
- 2000:1
- Image Size
- 76 cm - 762 cm
- Projection Distance
- 1.2 m - 13 m
- Throw Ratio
- 1.95 - 2.15:1
- Resolution
- WXGA - WXGA (1280 x 800) (native) / 1920 x 1080 (resized)
- 16:10
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- 180 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction, aspect control
- Eco-Mode technology, 6-segment colour wheel, BrilliantColor, DLP 3D Ready, VIDI Lighting Technology, Crestron RoomView
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
Speakers
- Internal
- Sound Output Mode
- Mono
- Output Power / Channel
- 7 Watt
- Speakers
- 1 x mixed channel
- 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 2 x audio line-in - mini-phone 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone 3.5 mm , 1 x remote control - 9 pin D-Sub (DB-9) , 1 x remote control - RJ-45 , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-out - RCA x 2
- Included Accessories
- Lens cover, wireless remote control
- Cables Included
- 1 x VGA cable - 1.8 m
- Security Features
- TUV GS, RoHS, ErP Ready
- Voltage Required
- 233 Watt
- Power Consumption Operational (Standby)
- 0.5 Watt
- 31 cm
- 9.5 cm
- 24.7 cm
- 2.5 kg
- Limited warranty - 3 years , Limited warranty - lamp - 6 months / 1000 hours
- Sound Emission
- 34 dB
- Sound Emission (Economic Mode)
- 31 dB
