NEC - LCD display - TFT - 27" - widescreen - 1920 x 1080
Quicklinx: 7T5RWS00 Mfr#: 60003154
  • High-Definition Multimedia Interface (HDMI)
The NEC MultiSync EA273WM is the flagship model in the NEC MultiSync EA Series and unites excellent display quality, ergonomics with low environmental impact. The NEC MultiSync EA273WM features an extremely thin LED backlight panel which results in an ultra-modern and slim design in combination with a premium feature set for the corporate office use. Ambient Light and Human Sensors enforce the sustainable product concept while offering improved ergonomics with 130 mm height adjustability.
  • Ambient light sensor
    With Auto Brightness function always sets optimized brightness level according to ambient light and content conditions.
  • Ergonomic office
    Full height adjustability (130 mm), swivel, tilt and pivot functionality ensures perfect individual ergonomic set-up.
  • Feature set for perfect office use
    Integrated speakers, headphone jack and USB Hub provide excellent options for office communication.
  • Human sensor
    Detects the presence of a person in front of the screen; display switches on/off automatically depending on the presence of the user.
NEC MultiSync EA273WM - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Stereo speakers, USB 2.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 25000:1 (dynamic)
Response Time
5 ms
Colour Support
16.8 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Voltage
AC 120/230 V
63.1 cm x 23 cm x 41.5 cm
7.2 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, MPR II, CSA, UL, TUV GS, GOST, cUL, DDC-2B, DDC-2Bi, MPR III, PCT, VESA EDID, CCC, TUV Ergo, DDC/CI, RoHS, ISO 9241-307, GEEA, ErP Ready
3-year warranty
Display Type
Energy Class
Class B
Diagonal Size
27"
Built-in Devices
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Controls & Adjustments
Volume, brightness, contrast, colour temperature
Infrared user sensor, ambient light sensor, No Touch Auto Adjust, power off timer, cable management cover, sRGB colour management, HDCP, Eco-Mode, ControlSync
7.2 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
DisplayPort , VGA , DVI-D , HDMI , USB 2.0 upstream (Type B) , 4 x USB 2.0 downstream , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+30
Swivel Angle
340
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Stand
1 x VGA cable , 1 x DVI cable , 1 x USB cable , 1 x audio cable , 1 x remote control cable
Power Supply
Internal
Input Voltage
AC 120/230 V
Power Consumption (Typical)
26 Watt
Power Consumption Stand by / Sleep
0.5 Watt
Included Software
Drivers & Utilities
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
5 °C
35 °C
30 - 80%
