The NEC MultiSync EA273WM is the flagship model in the NEC MultiSync EA Series and unites excellent display quality, ergonomics with low environmental impact. The NEC MultiSync EA273WM features an extremely thin LED backlight panel which results in an ultra-modern and slim design in combination with a premium feature set for the corporate office use. Ambient Light and Human Sensors enforce the sustainable product concept while offering improved ergonomics with 130 mm height adjustability.
Ambient light sensor
With Auto Brightness function always sets optimized brightness level according to ambient light and content conditions. -
Ergonomic office
Full height adjustability (130 mm), swivel, tilt and pivot functionality ensures perfect individual ergonomic set-up. -
Feature set for perfect office use
Integrated speakers, headphone jack and USB Hub provide excellent options for office communication. -
Human sensor
Detects the presence of a person in front of the screen; display switches on/off automatically depending on the presence of the user.
- NEC MultiSync EA273WM - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Stereo speakers, USB 2.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 25000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.8 million colours
- Input Connectors
- HDMI, DVI-D, VGA, DisplayPort
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V
- Black
- 63.1 cm x 23 cm x 41.5 cm
- 7.2 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, MPR II, CSA, UL, TUV GS, GOST, cUL, DDC-2B, DDC-2Bi, MPR III, PCT, VESA EDID, CCC, TUV Ergo, DDC/CI, RoHS, ISO 9241-307, GEEA, ErP Ready
- 3-year warranty
- Display Type
- Energy Class
- Class B
- Diagonal Size
- 27"
- Built-in Devices
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- Controls & Adjustments
- Volume, brightness, contrast, colour temperature
- Infrared user sensor, ambient light sensor, No Touch Auto Adjust, power off timer, cable management cover, sRGB colour management, HDCP, Eco-Mode, ControlSync
- Black
- 7.2 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1 Watt
- DisplayPort , VGA , DVI-D , HDMI , USB 2.0 upstream (Type B) , 4 x USB 2.0 downstream , Audio line-in , Headphones
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 340
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand
- Cables Included
- 1 x VGA cable , 1 x DVI cable , 1 x USB cable , 1 x audio cable , 1 x remote control cable
- Power Supply
- Internal
- Input Voltage
- AC 120/230 V
- Power Consumption (Typical)
- 26 Watt
- Power Consumption Stand by / Sleep
- 0.5 Watt
- Included Software
- Drivers & Utilities
- ENERGY STAR Certified
- Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
- 5 °C
- 35 °C
- 30 - 80%
