Mustek ScanExpress A3 USB 600 Pro - flatbed scanner - desktop - USB
Quicklinx: 7JXQWS00 Mfr#: 98-239-01010
Marketing description is not available.
Flatbed scanner - desktop
Interface Type
USB
Scanning Sensor Type
Contact Image Sensor (CIS)
Max Supported Document Size
A3 (297 x 420 mm)
Input Type
Grayscale / Color Depth
48-bit colour
Grayscale / Color Depth (External)
24-bit (16.7 million colours)
Optical Resolution
600 dpi x 1200 dpi
Interpolated Resolution
9600 dpi x 9600 dpi
Max Document Size
297 mm x 420 mm
Supported Document Type
Plain paper, bulk objects (such as books, magazines and other bound materials)
Document Feeder Type
Manual
Microsoft Windows 98SE/2000/ME/XP, Microsoft Windows Vista
Microsoft Certification
Certified for Windows Vista
38.4 cm x 56.3 cm x 8.7 cm
4.3 kg
Interface Type
USB
A3 (297 x 420 mm)
Scanner
Input Type
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 1200 dpi
9600 dpi x 9600 dpi
Scan Mode
Single-pass
Media Handling
Max Document Size
297 mm x 420 mm
Manual
Interfaces Details
USB - Type B
1 x USB cable
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
External power adapter
Power Consumption Operational (Standby)
20 Watt
Software Included
Drivers & Utilities
38.4 cm
56.3 cm
8.7 cm
4.3 kg
