Mustek ScanExpress a3 USB 2400 Pro Scanner
Quicklinx: 7WN4WS00 Mfr#: 05301394
The ScanExpress A3USB 2400 Pro from Mustek is the newest tabloid size scanner from Mustek. The scanning resolution is 2400 x 2400 which will give you beautiful in depth quality of documents and photos.
Mustek ScanExpress A3 USB 2400 Pro - flatbed scanner - desktop - USB 2.0
Flatbed scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
Contact Image Sensor (CIS)
Light Source
LED
Max Supported Document Size
A3 (297 x 420 mm)
Input Type
Grayscale / Color Depth
16-bit (64K grey levels) / 48-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
2400 dpi x 2400 dpi
Interpolated Resolution
9600 dpi x 9600 dpi
Max Document Size
297 mm x 420 mm
Supported Document Type
Plain paper
Document Feeder Type
Manual
Microsoft Windows Vista / XP / 7, Apple MacOS X 10.4 - 10.6
38.3 cm x 55.5 cm x 8.8 cm
4.3 kg
Interface Type
USB 2.0
A3 (297 x 420 mm)
Scanner
Input Type
Grayscale Depth
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
2400 dpi x 2400 dpi
9600 dpi x 9600 dpi
Scan Mode
Single-pass
Bulb / Light Source Type
LED
Media Handling
Max Document Size
297 mm x 420 mm
Plain paper
Manual
Interfaces Details
USB 2.0 - Type B
1 x USB cable
External power adapter
Power Consumption Operational (Standby)
20 Watt
Software Included
Drivers & Utilities, Adobe Acrobat Reader, ABBYY FineReader, ArcSoft MediaImpression
38.3 cm
55.5 cm
8.8 cm
4.3 kg
