Stay cool while gaming
Cooling your PC is essential for reliable performance. Made sure to include enough fan headers with full control to allow you to cool your system any way you want. -
Your in-game advantage
Outsmart and outperform your opponents in-game using an array of unique MSI GAMING tools. Clever hardware & software tools, created to keep you one step ahead of the competition and boost your skills. -
Be the first on the battlefield
This MSI GAMING motherboard supports all the latest storage standards. This allows you to connect any ultra-fast storage device, giving you in-game benefits. Start games faster, load levels faster and have a real advantage over your enemies. -
Immerse yourself into virtual worlds
Integrating the very best of cutting edge technologies on MSI hardware provides a smooth VR ride. Through joint efforts with major VR brands, combined with unique MSI features geared to VR, MSI brings gamers and VR professionals a vivid and realistic experience in which content truly comes alive. -
Sound that pulls you into the game
Get the most immersive sound experience when gaming. MSI Audio Boost delivers the highest sound quality through the use of premium quality audio components. This lets you enjoy breathtaking, game-changing sound to create the most exciting gameplay. -
Unmatched memory performance
MSI motherboards are crammed with features to fuel your gaming rig's memory with more speed, higher overclockability and increased stability. -
Designed for limitless tuning
Founded on experience and with a long history of creating the best performing motherboards packed with smart features, you can count on this motherboard to deliver the best performance under the most extreme conditions. Countless system tuning and troubleshooting tools are at your disposal to push your system to new heights and satisfy even the most demanding tweaker. -
Built on everlasting quality
Using only the finest quality components and integrating the latest technological innovations delivers the best possible gaming and professional experience. Rigorous quality testing under the most extreme conditions ensures a super reliable, high performance motherboard.
 - MSI Z370-A PRO - motherboard - ATX - LGA1151 Socket - Z370
- Product Type
 - Motherboard - ATX
- Chipset Type
 - Intel Z370
- Processor Socket
 - 1 x LGA1151 Socket
- Compatible Processors
 - Pentium, Celeron, Core i5, Core i3, Core i7 (supports 8th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
- Max RAM Size
 - 64 GB
- RAM Supported
 - 4 DIMM slots - DDR4, non-ECC, unbuffered
- Storage Ports
 - 6 x SATA-600 (RAID), 1 x M.2
- USB / FireWire Ports
 - 4 x USB 3.1 Gen 1 + 2 x USB 2.0 + (4 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
- Audio
 - HD Audio (8-channel)
- LAN
 - Gigabit Ethernet
- Product Type
 - Motherboard - ATX
- Chipset Type
 - Intel Z370
- Processor Socket
 - LGA1151 Socket
- Max Processors Qty
 - 1
Supported RAM
- Max Size
 - 64 GB
- Technology
 - DDR4
- Bus Clock
 - 2400 MHz, 2133 MHz, 2667 MHz, 3000 MHz (O.C.), 3200 MHz (O.C.), 3300 MHz (O.C.), 3400 MHz (O.C.), 3333 MHz (O.C.), 3466 MHz (O.C.), 3733 MHz (O.C.), 3600 MHz (O.C.), 3866 MHz (O.C.), 4000 MHz (O.C.)
- Supported RAM Integrity Check
 - Non-ECC
- Registered or Buffered
 - Unbuffered
 - Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
- Audio Codec
 - Realtek ALC892
 - High Definition Audio
LAN
- Network Controller
 - Realtek RTL8111H
- Network Interfaces
 - Gigabit Ethernet
- Expansion Slots
 - 1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 , 4 x PCIe 3.0 x1 , 1 x PCIe 3.0 x16 (x4 mode)
- Storage Interfaces
 - SATA-600 -connectors: 6 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 / PCIe 3.0 -connectors: 1 x M.2
 - 1 x DisplayPort , 1 x LAN (Gigabit Ethernet) , 4 x USB 3.1 Gen 1 , 2 x USB 2.0 , 1 x PS/2 keyboard / mouse , 1 x DVI-D , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-in - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x VGA
- Internal Interfaces
 - 4 x USB 2.0 - header , 4 x USB 3.1 Gen 1 - header , 1 x serial - header , 1 x parallel - header , 1 x audio - header
- Power Connectors
 - 24-pin main power connector, 8-pin ATX12V connector
- BIOS Features
 - MSI ClickBIOS 5
- Hardware Features
 - Intel Extreme Memory Profile (XMP) support, AMD CrossFireX technology support, MSI Audio Boost, MSI Guard-Pro, Debug LED, MSI Steel Armor, MSI Military Class V, Double ESD Protection, Intel Optane Memory Ready
- Included Accessories
 - I/O back plate
- Cables Included
 - 2 x Serial ATA cable
- Software Included
 - Drivers & Utilities, MSI Command Center, RAMdisk, MSI Live Update 6, MSI X-BOOST
 - 30.5 cm
 - 24.4 cm
            MSI Z370-A PRO Intel Z370 S1151 DDR4 USB3.1Gen2 ATX
