Personalize Your Gaming Rig
Connect external RGB strips and sync other RGB capable gear to set up your own colour scheme using only 1 application: Mystic Light Sync. Select any of the colours from the palette using your smartphone or the MSI Gaming App to match your system style. Feel like using a different colour? Completely change the look of your system in 1 second!
Fully Controllable Fan Headers
MSI FAN headers automatically detect fans running in DC or PWM mode for optimal tuning of fan speeds and silence. Hysteresis also makes your fans spin up fluently to make sure your system stays silent, no matter what.
Your In-Game Advantage
Outsmart and outperform your opponents in-game using an array of unique MSI GAMING tools. Clever hardware & software tools, created to keep you one step ahead of the competition and boost your skills.
- Gaming Hotkey.
- Gaming Device Port.
Stay cool while gaming
Cooling your PC is essential for reliable performance. They have made sure to include enough fan headers with full control to allow you to cool your system any way you want. -
Be the first on the battlefield
This MSI GAMING motherboard supports all the latest storage standards. This allows you to connect any ultra-fast storage device, giving you in-game benefits. Start games faster, load levels faster and have a real advantage over your enemies. -
Sound that pulls you into the game
Get the most immersive sound experience when gaming. MSI Audio Boost delivers the highest sound quality through the use of premium quality audio components. This lets you enjoy breathtaking, game-changing sound to create the most exciting gameplay. -
Dominate the game with the lowest latency
Get ready to crush your enemies on the battlefield with MSI GAMING LAN. Featuring the highest quality components tuned to deliver the best online gaming experience without lag. -
Unmatched memory performance
MSI motherboards are crammed with features to fuel your gaming rig's memory with more speed, higher overclockability and increased stability.
- MSI Z270 TOMAHAWK - motherboard - ATX - LGA1151 Socket - Z270
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z270
- Processor Socket
- 1 x LGA1151 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th and 7th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
- Max RAM Size
- 64 GB
- RAM Supported
- 4 DIMM slots - DDR4
- Storage Ports
- 6 x SATA-600 (RAID), 2 x M.2
- USB / FireWire Ports
- 1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 2 x USB 2.0 + (4 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z270
- Processor Socket
- LGA1151 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 64 GB
- Technology
- DDR4
- Bus Clock
- 2400 MHz, 2133 MHz, 2800 MHz (O.C.), 2600 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3600 MHz (O.C.), 3800 MHz (O.C.)
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
- Audio Codec
- Realtek ALC892
- High Definition Audio
LAN
- Network Controller
- Intel I219V
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 288-pin , 3 x PCIe 3.0 x16 (x16/x4/x1 modes) , 3 x PCIe 3.0 x1
- Storage Interfaces
- SATA-600 -connectors: 6 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 / PCIe 3.0 -connectors: 2 x M.2 - RAID 0 / RAID 1
- RAID Features
- Intel Smart Response Technology
- 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 4 x USB 3.1 Gen 1 , 2 x USB 2.0 , 1 x PS/2 keyboard / mouse , 1 x DVI-D , 1 x USB 3.1 Gen 2 , 1 x USB-C Gen2 , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-in - mini-jack , 1 x TOSLINK
- Internal Interfaces
- 4 x USB 2.0 - header , 4 x USB 3.1 Gen 1 - header , 1 x serial - header , 1 x parallel - header , 1 x audio - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Features
- MSI ClickBIOS 5
- Hardware Features
- Intel Extreme Memory Profile (XMP) support, AMD CrossFireX technology support, MSI Audio Boost, MSI Gaming Device Port, MSI Guard-Pro, Debug LED, MSI Mystic Light, MSI Steel Armor, Game Boost, MSI Military Class V, LAN Protect, Double ESD Protection, Intel Optane Memory Ready
- Software Included
- MSI Command Center, RAMdisk, MSI Live Update 6, MSI Gaming Hotkey, MSI Gaming LAN Manager, MSI CPU-Z, MSI X-BOOST
- 30.4 cm
- 24.3 cm
