USB 3.1 allows for speeds up to 10 Gbps, doubling the speed compared to USB 3.0 and 20x faster than legacy USB 2.0. USB 3.1 is even faster than SATAIII! Transferring your favorite games, music and movies over USB has never been faster.
Delivering speeds up to 32Gb/s using Gen3 x4, Turbo M.2 is more than 5 times faster than a regular SATA III connection! Enjoy a blazing fast system boot up and insanely fast loading of applications and games with MSI motherboards.
Turbo M.2 is the successor to M.2 10 Gb/s, offering 3 times more performance up to 32 Gb/s using Gen3 x4. M.2 is packed in a small form factor and is compatible with 3 different sizes to fit most storage solutions.
SATA Express introduces a solution in high speed storage through PCI-Express, providing more bandwidth for the SSDs up to 10 Gb/s.
With a large number of PCI-Express 3.0 x16 slots for every MSI motherboard, you get to choose optimal placement for your graphics cards for better fitting and airflow up to Quad SLI/CF. That way, you can enjoy the best graphics at the highest framerate jumping off from your screen when running a NVIDIA SLI or AMD CrossFire setup.
Military Class 4 is the next step in high quality components. The Super Ferrite Choke and Solid CAP will make sure that your PC runs more stable under extreme gaming conditions.
MSI USB 3.1
USB 3.1 allows for speeds up to 10 Gbps, doubling the speed compared to USB 3.0 and 20x faster than legacy USB 2.0. USB 3.1 is even faster than SATAIII! Transferring your favorite games, music and movies over USB has never been faster. -
Push your SSD even harder with Turbo M.2
Delivering speeds up to 32Gb/s using Gen3 x4, Turbo M.2 is more than 5 times faster than a regular SATA III connection! Enjoy a blazing fast system boot up and insanely fast loading of applications and games with MSI motherboards. -
Next generation M.2
Turbo M.2 is the successor to M.2 10 Gb/s, offering 3 times more performance up to 32 Gb/s using Gen3 x4. M.2 is packed in a small form factor and is compatible with 3 different sizes to fit most storage solutions. -
Fast storage with SATA Express
SATA Express introduces a solution in high speed storage through PCI-Express, providing more bandwidth for the SSDs up to 10 Gb/s. -
Optimized for multiple graphics cards
With a large number of PCI-Express 3.0 x16 slots for every MSI motherboard, you get to choose optimal placement for your graphics cards for better fitting and airflow up to Quad SLI/CF. That way, you can enjoy the best graphics at the highest framerate jumping off from your screen when running a NVIDIA SLI or AMD CrossFire setup. -
Military class 4
Military Class 4 is the next step in high quality components. The Super Ferrite Choke and Solid CAP will make sure that your PC runs more stable under extreme gaming conditions. -
Super ferrite chokes
Super Ferrite Chokes use a Ferrite core that is Super-Permeable. This allows the Super Ferrite Chokes to run at a 35 degree Celsius lower temperature, have a 30% higher current capacity, a 20% improvement in power efficiency and better overclocking power stability. -
Solid CAP
With their aluminum core design and Japanese made quality, Solid CAPs are made for high-end design motherboard. Not only do Solid CAPs could provide lower Equivalent Series Resistance (ESR), but also work firmly for over-10-year. -
Circuit protection
Carefully selected materials, multiple PCB layers and shielding result in the best circuit protection for these motherboards. -
ECO power
With MSI ECO Center you can physically cut the power to unused chips to save up to 19% power usage. -
Humidity protection
10% Reduction in moisture absorption helps prevent "Conductive Anodic Filament". Untreated PCB's can have 10x higher failure rate. -
High temperature protection
All key components used in MSI motherboards have all passed military testing ensuring stable operation in the harshest environments. -
ESD protection
Each and every I/O port is protected against the hazards of Electro Static Discharge. -
EMI protection
All MSI motherboards comply with stringent American FCC regulations and reduce the impact of Electromagnetic Interference. -
Intel GigabiT LAN
Always connected with Intel Gigabit LAN networking. The MSI X99 motherboards come equipped with the high quality network solution from Intel. Optimized for multimedia and gaming use to deliver a stable and fast network connection. -
ECO Power
ECO Power helps users to manage their hardware and power usage. Save up to 19% power consumption by completely disabling unnecessary hardware. ECO Power not only lowers the power consumption but also avoids short circuiting and signal noise.
- MSI X99A RAIDER - motherboard - ATX - LGA2011-v3 Socket - X99
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel X99 Express
- Processor Socket
- 1 x LGA2011-v3 Socket
- Compatible Processors
- Core i7 Extreme Edition
- Max RAM Size
- 128 GB
- RAM Supported
- 8 DIMM slots - DDR4, non-ECC, ECC, registered, unbuffered
- Storage Ports
- 6 x SATA-600 (RAID), 4 x SATA-600, 1 x SATA Express port, 1 x M.2
- USB / FireWire Ports
- 2 x USB 3.1 + 4 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 2 x USB 2.0 via headers)
- Graphics
- No graphics
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Microsoft Certification
- Compatible with Windows 7
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel X99 Express
- Processor Socket
- LGA2011-v3 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 128 GB
- Technology
- DDR4
- Bus Clock
- 2133 MHz, 2666 MHz (O.C.), 2600 MHz (O.C.), 2400 MHz (O.C.), 2200 MHz (O.C.), 3000 MHz (O.C.), 2750 MHz (O.C.), 3110 MHz (O.C.), 3333 MHz (O.C.)
- Supported RAM Integrity Check
- Non-ECC, ECC
- Registered or Buffered
- Registered, unbuffered
- Intel Extreme Memory Profiles (XMP), quad channel memory architecture
Graphics
- Graphics Controller
- No graphics
Audio
- Audio Codec
- Realtek ALC892
- High Definition Audio
LAN
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 8 x DIMM 288-pin , 3 x PCIe 3.0 x16 (dual x16 mode; triple: x16, x8, x8 mode) , 2 x PCIe 2.0 x1 , 1 x M.2 socket
- Storage Interfaces
- SATA-600 -connectors: 6 x 7pin SATA, 1 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices
- RAID Features
- Intel Smart Response Technology
- 2 x USB 3.1 , 4 x USB 2.0 , 4 x USB 3.0 , 1 x PS/2 keyboard / mouse , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x TOSLINK
- Internal Interfaces
- 2 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Features
- DMI support, MSI ClickBIOS 4
- Hardware Features
- NVIDIA 3-way SLI Technology Support, Intel Extreme Memory Profile (XMP) support, Super Charger, Super Ferrite Choke (SFC), AMD 3-way CrossFireX technology support, MSI Military Class IV, OC Genie 4, MSI Fast Boot, Clear CMOS Button, MSI Guard-Pro, Turbo M.2, MSI ECO Power
- Software Included
- MSI Command Center, RAMdisk, MSI Live Update 6, MSI ECO Center
- Plug and Play
- 30.5 cm
- 24.4 cm
MSI X99A RAIDER Intel S2011-3 DDR4 USB3.1 PCIe SATA3 M.2 ATX
