Carbon-fiber-reinforced polymer is used extensively the world of car racing, where each second counts. Besides its strength and futuristic look, carbon-fiber is also very light for ultimate performance to pursue track records. MSI GAMING motherboards are dedicated to ultimate performance and the best gaming experience. The CARBON motherboards black scheme combines flashiness with sophistication that is sure to make your PC stand out in looks and performance.
Black with carbon skin
Carbon-fiber-reinforced polymer is used extensively the world of car racing, where each second counts. Besides its strength and futuristic look, carbon-fiber is also very light for ultimate performance to pursue track records. MSI GAMING motherboards are dedicated to ultimate performance and the best gaming experience. The CARBON motherboards black scheme combines flashiness with sophistication that is sure to make your PC stand out in looks and performance. -
Mystic Light
Customize and set up your own color scheme with Mystic Light. Make your build look on fire or cold as ice. You are in control. You can select any of the colors from the palette to match your systems' design. Tired of always the same color? Just change it to another one using the easy to use Mystic Light APP available on PC, phone and tablet, and make your PC look & feel brand new! -
Mystic Light Extension
Designed for anyone who simply wants to have a perfectly stylish gaming rig. With MSI's Mystic Light Extension header, it provides the most intuitive way to control the fascinated LED strip without the ordinary controller. Just install the standard 12V RGB strips onto the 4-pin Mystic Light Extension RGB-strip header, then control your lighting to any style you want. Extend the Mystic Light to whole gaming rig and your gaming room. -
Performance and stability
With traditional memory design the memory signals are often distorted by electromagnetic signals from other components, making the system perform slower or become unstable. MSI introduces DDR4 Boost technology with optimized traces and fully isolated memory circuitry. This design ensures the memory signals stay pure for optimal performance and stability. -
Dominate the game with low latency
Get ready to crush your enemies on the battlefield with MSI GAMING LAN, featuring carefully selected components to ensure the best online gaming experience without lag. -
Dedicated gaming lan with InteL
Experience a more fluid game with Intel i218 LAN. Intel i218 LAN is designed to deliver high performance when gaming, delivering more throughput than other solutions. Intel i218 LAN is optimized for championship level online and LAN eSports by reducing CPU overhead and offering exceptionally high TCP and UDP throughput. This way, your CPU can be used more effectively and you can enjoy more FPS when gaming. -
Gaming optimized bandwith management
Dedicated to giving you the best online gaming experience with optimized traffic prioritization and low latency, MSI GAMING LAN Manager automatically classifies and prioritizes the latency-sensitive applications for online games. -
LAN Protect
Featuring 15KV anti-surge protection to shield your network from lightning strikes and static electricity, LAN Protect is a LAN connector designed to give you the best networking experience. It's highlighted with a red LED inside the RJ45 connector to show its functionality. -
Reward your ears with studio grade sound quality
With Audio Boost 3, powered by Nahimic Sound technology, we're delivering the highest sound quality through the use of premium quality audio components. That way, you can enjoy breathtaking, crystal clear sound and music through 8-channel HD Audio or high impedance headphones and truly dominate the game.
- MSI X99A GAMING PRO CARBON - motherboard - ATX - LGA2011-v3 Socket - X99
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel X99 Express
- Processor Socket
- 1 x LGA2011-v3 Socket
- Compatible Processors
- Core i7 Extreme Edition, Core i7
- Max RAM Size
- 128 GB
- RAM Supported
- 8 DIMM slots - DDR4
- Storage Ports
- 4 x SATA-600 (RAID), 4 x SATA-600, 1 x SATA Express port, 1 x M.2, 1 x U.2 port
- USB / FireWire Ports
- 1 x USB-C Gen 2 + 1 x USB-C Gen 1 + 1 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 4 x USB 2.0 + (4 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- 3-year warranty
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel X99 Express
- Processor Socket
- LGA2011-v3 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 128 GB
- Technology
- DDR4
- Bus Clock
- 2133 MHz, 2800 MHz (O.C.), 2933 MHz (O.C.), 2666 MHz (O.C.), 2600 MHz (O.C.), 2400 MHz (O.C.), 2200 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3400 MHz (O.C.), 3333 MHz (O.C.), 3466 MHz (O.C.)
- Intel Extreme Memory Profiles (XMP), quad channel memory architecture
Audio
- Audio Codec
- Realtek ALC1150
- High Definition Audio
LAN
- Network Controller
- Intel I218V
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 8 x DIMM 288-pin , 4 x PCIe 3.0 x16 (dual x16 mode; triple: x16, x16, x8 mode; quad: x16, x8, x8, x8 mode; single card: x16 mode) , 2 x PCIe 2.0 x1
- Storage Interfaces
- SATA-600 -connectors: 4 x 7pin SATA, 1 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 / PCIe 3.0 -connectors: 1 x M.2, 1 x U.2 , SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices
- RAID Features
- Intel Smart Response Technology
- 4 x USB 3.1 Gen 1 , 4 x USB 2.0 , 1 x USB 3.1 Gen 2 , 1 x PS/2 keyboard / mouse , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x TOSLINK , 1 x USB-C Gen2
- Internal Interfaces
- 4 x USB 2.0 - header , 4 x USB 3.1 Gen 1 - header , 1 x audio - header , 1 x USB 3.1 Gen 1 - Type C
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Features
- UEFI BIOS, MSI ClickBIOS 5
- Hardware Features
- NVIDIA 3-way SLI Technology Support, Intel Extreme Memory Profile (XMP) support, Super Charger, Intel Smart Response Technology, AMD 3-way CrossFireX technology support, MSI Gaming Device Port, MSI Guard-Pro, Debug LED, MSI Mystic Light, Nahimic Audio Enhacer, MSI Steel Armor, MSI Audio Boost 3, Game Boost, MSI Military Class V, LAN Protect, Double ESD Protection, SteelSeries Certified (SSC), USB Redriver, overvoltage protection
- Included Accessories
- I/O back plate, cable labels
- Software Included
- MSI Command Center, RAMdisk, MSI Gaming App, MSI Gaming Hotkey, MSI Gaming LAN Manager, MSI CPU-Z
- 30.5 cm
- 24.4 cm
- Limited warranty - parts and labour - 3 years
MSI X99A GAMING PRO CARBON Intel X99 S2011-3 DDR4 U.2 M.2
