MSI GAMING motherboards are designed to provide gamers with outstanding features and technology. Backed by the imposing looks of MSI's Dragon, each motherboard is an engineering masterpiece tailored to gaming perfection. Assemble and edit your recordings using the simple and straightforward video editor. Game Capture Auto Detect allows for automatic streaming when starting a game.
Let the games begin
MSI GAMING motherboards are designed to provide gamers with outstanding features and technology. Backed by the imposing looks of MSI's Dragon, each motherboard is an engineering masterpiece tailored to gaming perfection. -
MSI USB 3.1 2x faster
USB 3.1 allows for speeds up to 10 Gbps, doubling the speed compared to USB 3.0 and 20x faster than legacy USB 2.0. USB 3.1 is even faster than SATA III! Transferring your favorite games, music and movies over USB has never been faster. -
Video editor & game detection
Assemble and edit your recordings using the simple and straightforward video editor. Game Capture Auto Detect allows for automatic streaming when starting a game. -
Webcam & chroma key
Add a webcam and show your game face -
Share your broadcast
Share your broadcast and conquer the world -
Real-time notes
Draw attention whilst casting with in-game annotations -
Record & stream
Use XSplit Gamecaster to stream & record all of your gaming activities -
OC engine
Run into unstable situations when pushing your CPU to the limit? This occurs because the internal clocks are linked through the 100 MHz BCLK strap. Thanks to a integrated Clock Generator, MSI motherboards support more flexible BCLK adjustments, from 100 / 125 / 167 MHz straps. Using these straps prevents system crashing while overclocking on the edge and opens doors to achieve the absolute maximum. The MSI X99 motherboards all come with the next generation Clock Generator offering even lower jitter and power consumption resulting in even higher stability under extreme conditions. -
More speed, more bandwidth, less power
MSI engineers made sure you can enjoy high speed DDR4 compatibility. DDR4 brings higher memory speeds at even lower power usage as low as 1.2v. DDR4 offers higher volume sticks, this means larger memory configurations are possible up to 128 GB. -
Reward your ears with true quality
Get ready for ear-drum shattering sound, with MSI Audio Boost 2! With Audio Boost 2 you get high audio quality due to the use of Creative Sound Blaster Cinema 2. So you can enjoy crystal clear sound and music through 8-channel HD Audio. -
Isolated audio PCB
With traditional onboard audio the signal is distorted by electromagnetic signals from the rest of the PCB. Audio Boost 2 acts like a dedicated soundcard by physically isolating the audio circuitry which is separated by a red LED path. Less interference gives you a more clear audio signal. -
Direct audio power
Enjoy a heavy caliber audio experience with Direct Audio Power. A dedicated power input to Audio Boost 2 allows for a more powerful and stable power delivery, resulting in a more explosive and pure sound experience. -
Thanks to Creative Sound Blaster Cinema 2, you're getting amazing surround sound with just stereo headphones or speakers. Creative Sound Blaster Cinema 2 enables you to clearly hear specific sounds in gaming environments. Hear your enemies perfectly, make your ears a decisive tool to finish on top. -
EMI shielding
To shield the audio core from EMI (Electromagnetic Interference) caused by other add-in cards the audio chip is protected by a high-grade EMI cover with backlight illumination. -
Dedicated headhpone amplifier
The built-in dedicated headphone amplifier rewards your high quality headphone with amazing studio level sound quality delivered from your gaming PC. Tired of having to connect your headset in difficult to reach places? MSI GAMING motherboards are designed to be easy to use, featuring front & rear audio outputs fueled by Audio Boost 2. -
USB audio power
When connecting multiple USB devices, most motherboards will be unable to deliver a strong 5 V power signal to all USB ports. This is highly noticeable with high-quality external USB DACs where sound quality degrades as the motherboard is unable to deliver a perfect USB signal.
- MSI X99A GAMING 7 - motherboard - ATX - LGA2011-v3 Socket - X99
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel X99 Express
- Processor Socket
- 1 x LGA2011-v3 Socket
- Compatible Processors
- Core i7 Extreme Edition, Core i7, Xeon E5-2600 v3 series, Xeon E5-1600 v3 series
- Max RAM Size
- 128 GB
- RAM Supported
- 8 DIMM slots - DDR4, non-ECC, registered, unbuffered
- Storage Ports
- 6 x SATA-600 (RAID), 4 x SATA-600, 1 x SATA Express port, 1 x M.2
- USB / FireWire Ports
- 2 x USB 3.1 + 6 x USB 3.0 + 2 x USB 2.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Microsoft Certification
- Compatible with Windows 7
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel X99 Express
- Processor Socket
- LGA2011-v3 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 128 GB
- Technology
- DDR4
- Bus Clock
- 2133 MHz, 2666 MHz (O.C.), 2600 MHz (O.C.), 2400 MHz (O.C.), 2200 MHz (O.C.), 3000 MHz (O.C.), 2750 MHz (O.C.), 3110 MHz (O.C.), 3333 MHz (O.C.)
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Registered, unbuffered
- Quad channel memory architecture
Audio
- Audio Codec
- Realtek ALC1150
- High Definition Audio, Sound Blaster Cinema 2
LAN
- Network Controller
- Killer Gaming E2205
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 8 x DIMM 288-pin , 4 x PCIe 3.0 x16 (dual x16 mode; triple: x16, x16, x8 mode) , 2 x PCIe 2.0 x1
- Storage Interfaces
- SATA-600 -connectors: 6 x 7pin SATA, 1 x M.2, 1 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices
- RAID Features
- Intel Smart Response Technology
- 2 x USB 3.1 , 2 x USB 2.0 , 6 x USB 3.0 , 1 x PS/2 keyboard / mouse , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x TOSLINK
- Internal Interfaces
- 4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x audio - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Features
- DMI support, MSI ClickBIOS 4, MSI MultiBIOS II
- Hardware Features
- NVIDIA 3-way SLI Technology Support, Hi-c CAP, Super Charger, Intel Smart Response Technology, Super Ferrite Choke (SFC), AMD 3-way CrossFireX technology support, Onboard Button, Easy Button 3, Front Audio Headphone Amplifier, Nichicon High-end Audio Capacitors, MSI Military Class IV, OC Genie 4, Gold Plated Audio Hardware, Clear CMOS Button, MSI Gaming Device Port, MSI Audio Boost 2, MSI Guard-Pro, Debug LED, Turbo M.2, MSI USB Audio Power
- Included Accessories
- I/O back plate, "Do-Not-Disturb" door hanger, case badge, cable labels
- Software Included
- MSI Command Center, RAMdisk, MSI Live Update 6, MSI Gaming App
- Plug and Play
- 30.5 cm
- 24.4 cm
