MSI X370 GAMING PRO AMD AM4 X370 DDR4 M.2 USB3.1 ATX
Quicklinx: D0PZWS00 Mfr#: X370 GAMING PRO
Marketing description is not available.
  • Enhanced audio experience
    With high definition audio (8-channel) and Realtek ALC1220 Audio Codec, the MSI X370 GAMING PRO motherboard delivers a rich, immersive sound experience. This feature, complemented by Nahimic 2 Sound Technology, ensures clear, crisp audio for gaming, music, and movies.
  • Robust expansion options
    Offering a wide range of expansion slots including 4 DIMM 288-pin for RAM, 2 PCIe 3.0 x16, and additional PCIe 2.0 slots, the motherboard supports extensive upgrade possibilities. Whether for gaming, content creation, or multitasking, these slots accommodate various components to enhance your system's performance.
  • Versatile connectivity
    The motherboard features a comprehensive suite of interfaces including USB 3.1 Gen 1 and Gen 2, USB-C Gen2, and Gigabit Ethernet for high-speed data transfer and reliable Internet connections. HDMI and DVI-D outputs cater to diverse display needs, ensuring compatibility with a wide range of monitors and projectors.
  • Advanced storage solutions
    With support for M.2 socket and Serial ATA-600 (RAID), the MSI X370 GAMING PRO allows for fast data access and storage flexibility. The inclusion of 6 x SATA-600 ports and 2 x M.2 slots enables high-speed storage configurations, optimizing your system for quick boot times and rapid application loading.
  • Durable and reliable
    Built with MSI Military Class IV components, the motherboard promises durability and reliability under various conditions. Features like Double ESD Protection, LAN Protect, and MSI Steel Armor safeguard the system against electrical surges and physical damage, ensuring a long-lasting computing experience.
MSI X370 GAMING PRO - motherboard - ATX - Socket AM4 - AMD X370
Motherboard - ATX
Chipset Type
AMD X370
Processor Socket
1 x Socket AM4
Compatible Processors
Athlon, A series, Ryzen (supports 7th Generation A-series / Athlon)
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4, non-ECC, ECC (operate in non-ECC mode), unbuffered
Storage Ports
6 x SATA-600 (RAID), 2 x M.2
USB / FireWire Ports
1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 2 x USB 2.0 + (4 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
2 GB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
3-year warranty
Motherboard - ATX
Chipset Type
AMD X370
Processor Socket
Socket AM4
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2400 MHz, 1866 MHz, 2133 MHz, 2933 MHz (O.C.), 2667 MHz (O.C.), 3200 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC, ECC (operate in non-ECC mode)
Registered or Buffered
Unbuffered
Dual channel memory architecture, supported ECC modules operate in non-ECC mode
Graphics
2 GB
Audio
Audio Codec
Realtek ALC1220
High Definition Audio
LAN
Network Controller
Intel I211-AT
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 2 x PCIe 3.0 x16 (x16/x0, x8/x8 mode (with AMD Ryzen CPU); x8/x0 mode (with AMD 7th Generation A-series/Athlon CPU)) , 3 x PCIe 2.0 x1 , 1 x PCIe 2.0 x16 (x4 mode (auto turn-off if M.2 is occupied))
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 , SATA-600 / PCIe 3.0 -connectors: 2 x M.2
1 x LAN (Gigabit Ethernet) , 4 x USB 3.1 Gen 1 , 1 x PS/2 keyboard / mouse , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x USB-C Gen2 , 1 x USB 3.1 Gen 2 , 1 x HDMI , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 2 x USB 2.0 , 1 x DVI-D , 1 x TOSLINK
Internal Interfaces
4 x USB 2.0 - header , 4 x USB 3.1 Gen 1 - header , 1 x audio - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Features
MSI ClickBIOS 5
Hardware Features
NVIDIA 2-way SLI Technology Support, AMD CrossFireX technology support, AMD 3-way CrossFireX technology support, MSI Military Class IV, MSI Guard-Pro, Debug LED, MSI Mystic Light, MSI Steel Armor, Game Boost, LAN Protect, Double ESD Protection, MSI Audio Boost 4, Nahimic 2 Sound Technology
Software Included
MSI Live Update, MSI Command Center, RAMdisk, MSI Gaming Hotkey, MSI Gaming LAN Manager, MSI X-BOOST
WHQL
30.5 cm
24.4 cm
Limited warranty - 3 years
