X299 GAMING PRO CARBON AC
Intel X299 Motherboard
• Supports New Intel® Core™ X-series Processor Family for LGA 2066 socket
• Support Quad Channel DDR4-4133(OC)+, Dual Channel DDR4-4500(OC)+
• MYSTIC LIGHT: 16.8 million colors / 17 effects controlled in one click with MYSTIC LIGHT APP or mobile devices.
• 3D Printing Support: exchangeable cover and 3D X-MOUNTING screws.
• Designed for Extreme Performance: TURBO SOCKET with GAME BOOST, DIGITALL POWER Design
• Lightning Fast Game experience: TWIN TURBO M.2 with M.2 Shield and Intel Optane Memory Ready, Turbo U.2, LIGHTNING USB 3.1 GEN2
• VR READY and VR BOOST: Best virtual reality game experience without latency, reduces motion sickness. Supports Nahimic VR & TriDef VR.
• AUDIO BOOST 4 with NAHIMIC 2+: Reward your ears with studio grade sound quality for the most immersive gaming experience
• DDR4 BOOST with STEEL ARMOR: Give your DDR4 memory a performance boost
• GAMING LAN and Wireless support, powered by Intel®: The best online gaming experience with lowest latency and bandwidth management.
• MULTI-GPU: With STEEL ARMOR PCI-E slots. Supports 3-Way NVIDIA SLI™ & AMD Crossfire™
• SYSTEM SAVER: 3 easy to use options to successfully boot your system again.
• In-Game Weapons: GAME BOOST, GAMING HOTKEY, X-BOOST, XSPLIT GAMECASTER, APP MANAGER
• GAMING CERTIFIED: 24-hour on- and offline game and motherboard testing by eSports players
• Click BIOS 5: Award-winning BIOS with high resolution scalable font, favorites and search function
• WHQL certified for Windows 10
Stay cool while gaming
Cooling your PC is essential for reliable performance. Enough fan headers with full control are provided to allow you to cool your system any way you want. -
Be the first on the battlefield
This MSI gaming motherboard supports many storage standards. This allows you to connect any ultra-fast storage device, giving you in-game benefits. Start games faster, load levels faster and have a real advantage over your enemies. -
Unmatched memory performance
MSI motherboards are crammed with features to fuel your gaming rig's memory with more speed, higher overclockability and increased stability. -
Maximize your USB device performance
Transfer your favorite games, music and movies over USB faster than ever. MSI offers a wide variety of options to connect and boost your USB 3.1 devices, delivering lightning-fast transfer speeds!
- MSI X299 GAMING PRO CARBON AC - motherboard - ATX - LGA2066 Socket - X299
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel X299
- Processor Socket
- 1 x LGA2066 Socket
- Compatible Processors
- Core X
- Max RAM Size
- 128 GB
- RAM Supported
- 8 DIMM slots - DDR4
- Storage Ports
- 8 x SATA-600 (RAID), 2 x M.2, 1 x U.2
- USB / FireWire Ports
- 1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 3 x USB 2.0 + (1 x USB-C Gen 2 + 4 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Bluetooth, Gigabit Ethernet, 802.11a/b/g/n/ac
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel X299
- Processor Socket
- LGA2066 Socket
- Max Processors Qty
- 1
- Core X
Supported RAM
- Max Size
- 128 GB
- Technology
- DDR4
- Bus Clock
- 2400 MHz, 2133 MHz, 2666 MHz, 2800 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3300 MHz (O.C.), 3400 MHz (O.C.), 3333 MHz (O.C.), 3466 MHz (O.C.), 3733 MHz (O.C.), 3600 MHz (O.C.), 3866 MHz (O.C.), 4000 MHz (O.C.), 4133 MHz (O.C.), 4266 MHz (O.C.)
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP), quad channel memory architecture
Audio
- Audio Codec
- Realtek ALC1220
- High Definition Audio
LAN
- Network Controller
- Intel I219V / Intel Dual Band Wireless-AC 8265
- Network Interfaces
- Expansion Slots
- 1 x CPU , 8 x DIMM 288-pin , 4 x PCIe 3.0 x16 (44-lane CPU (x16/x4/x16/x8 mode), 28-lane CPU (x16/x4/x8/x0, x8/x4/x8/x8 modes), 16-lane CPU (x8/x0/x8/x0, x8/x4/x4/x0 modes)) , 2 x PCIe 3.0 x1
- Storage Interfaces
- SATA-600 -connectors: 8 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 / PCIe 3.0 -connectors: 2 x M.2 - RAID 0 / RAID 1 , PCIe 3.0 -connectors: 1 x U.2
- RAID Features
- Intel Smart Response Technology
- 1 x LAN (Gigabit Ethernet) , 4 x USB 3.1 Gen 1 , 3 x USB 2.0 , 1 x PS/2 keyboard / mouse , 1 x TOSLINK , 1 x USB 3.1 Gen 2 , 1 x USB-C Gen2 , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-in - mini-jack
- Internal Interfaces
- 4 x USB 2.0 - header , 4 x USB 3.1 Gen 1 - header , 1 x audio - header , 1 x USB-C Gen2 - header
- Power Connectors
- 4-pin ATX12V connector, 24-pin main power connector, 8-pin ATX12V connector
- BIOS Features
- Dual BIOS, BIOS FlashBack+, MSI ClickBIOS 5
- Hardware Features
- NVIDIA 3-way SLI Technology Support, Intel Extreme Memory Profile (XMP) support, Intel Smart Response Technology, AMD 3-way CrossFireX technology support, Clear CMOS Button, MSI Gaming Device Port, MSI Mystic Light, MSI Steel Armor, Game Boost, LAN Protect, 3D printing friendly, Intel Optane Memory Ready, MSI Audio Boost 4, TURBO SOCKET, Nahimic 2+ Sound Technology
- Included Accessories
- I/O back plate, case badge, cable labels, RGB (RGBW) LED strip extension cable, 3D printing mount package
- Cables Included
- 4 x Serial ATA cable , 1 x SLI bridge
- Software Included
- Drivers & Utilities, MSI Command Center, RAMdisk, MSI Live Update 6, MSI Gaming Hotkey, MSI Gaming LAN Manager, MSI CPU-Z, MSI X-BOOST
- WHQL
- 30.5 cm
- 24.4 cm
