MSI X299 GAMING M7 ACK Intel X299 S2066 DDR4 U.2 USB3.1 ATX
Quicklinx: CYRPWS00 Mfr#: X299 GAMING M7 ACK
  • IEEE 802.11n
X299 GAMING M7 ACK
Intel X299 Motherboard
• Supports New Intel® Core™ X-series Processor Family for LGA 2066 socket
• Support Quad Channel DDR4-4133(OC)+, Dual Channel DDR4-4500(OC)+
• M.2 SHIELD FROZR: Strengthened built-in M.2 thermal solution. Keeps M.2 safer and faster.
• 3D Printing Support: Modify and customize your system with the use of special 3D screws.
• Mystic Light: Personalize your PC with 16.8 million colors / 17 effects controlled in one click with the Mystic Light APP or a mobile device.
• Audio Boost 4 PRO: Isolated audio with 2x audio processors & Nahimic 2+ for the most immersive gaming experience.
• Killer DoubleShot PRO: Delivers industry-leading speed using Killer’s Lag and Latency Reduction™ Technology via both Killer Ethernet and WIFI
• Designed for Extreme Performance: TURBO SOCKET with GAME BOOST, DIGITALL POWER Design
• Lightning Fast Game experience: TWIN TURBO M.2 and Intel Optane Memory Ready, Turbo U.2, LIGHTNING USB 3.1 GEN2
• DDR4 Boost with Steel Armor: Fully isolated, shielded and optimized DDR4 PCB design to give your DDR4 memory a performance boost.
• MULTI-GPU: With STEEL ARMOR PCI-E slots. Supports 3-Way NVIDIA SLI™ & 3-Way AMD Crossfire™
• SYSTEM SAVER: 3 easy to use options to successfully boot your system again.
  • Stay cool while gaming
    Cooling your PC is essential for reliable performance. Enough fan headers with full control are provided to allow you to cool your system any way you want.
  • Be the first on the battlefield
    This MSI gaming motherboard supports many storage standards. This allows you to connect any ultra-fast storage device, giving you in-game benefits. Start games faster, load levels faster and have a real advantage over your enemies.
  • Unmatched memory performance
    MSI motherboards are crammed with features to fuel your gaming rig's memory with more speed, higher overclockability and increased stability.
  • Maximize your USB device performance
    Transfer your favorite games, music and movies over USB faster than ever. MSI offers a wide variety of options to connect and boost your USB 3.1 devices, delivering lightning-fast transfer speeds!
MSI X299 GAMING M7 ACK - motherboard - ATX - LGA2066 Socket - X299
Motherboard - ATX
Chipset Type
Intel X299
Processor Socket
1 x LGA2066 Socket
Compatible Processors
Core X
Max RAM Size
128 GB
RAM Supported
8 DIMM slots - DDR4
Storage Ports
8 x SATA-600 (RAID), 2 x M.2, 1 x U.2
USB / FireWire Ports
1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 3 x USB 2.0 + (1 x USB-C Gen 2 + 4 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Bluetooth, Gigabit Ethernet, 802.11a/b/g/n/ac
Motherboard - ATX
Chipset Type
Intel X299
Processor Socket
LGA2066 Socket
Max Processors Qty
1
Core X
Supported RAM
Max Size
128 GB
DDR4
Bus Clock
2400 MHz, 2133 MHz, 2666 MHz, 2800 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3300 MHz (O.C.), 3400 MHz (O.C.), 3333 MHz (O.C.), 3466 MHz (O.C.), 3733 MHz (O.C.), 3600 MHz (O.C.), 3866 MHz (O.C.), 4000 MHz (O.C.), 4133 MHz (O.C.), 4266 MHz (O.C.)
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP), quad channel memory architecture
Audio
Audio Codec
Realtek ALC1220
High Definition Audio
LAN
Network Controller
Killer Gaming E2500 / 1535
Network Interfaces
Expansion Slots
1 x CPU , 8 x DIMM 288-pin , 4 x PCIe 3.0 x16 (44-lane CPU (x16/x4/x16/x8 mode), 28-lane CPU (x16/x4/x8/x0, x8/x4/x8/x8 modes), 16-lane CPU (x8/x0/x8/x0, x8/x4/x4/x0 modes)) , 2 x PCIe 3.0 x1
Storage Interfaces
SATA-600 -connectors: 8 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 / PCIe 3.0 -connectors: 2 x M.2 - RAID 0 / RAID 1 , PCIe 3.0 -connectors: 1 x U.2
RAID Features
Intel Smart Response Technology
1 x LAN (Gigabit Ethernet) , 4 x USB 3.1 Gen 1 , 3 x USB 2.0 , 1 x PS/2 keyboard / mouse , 1 x TOSLINK , 1 x USB 3.1 Gen 2 , 1 x USB-C Gen2 , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-in - mini-jack
Internal Interfaces
4 x USB 2.0 - header , 4 x USB 3.1 Gen 1 - header , 1 x audio - header , 1 x USB-C Gen2 - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector, 8-pin ATX12V connector
BIOS Features
Dual BIOS, BIOS FlashBack+, MSI ClickBIOS 5
Hardware Features
NVIDIA 3-way SLI Technology Support, Intel Extreme Memory Profile (XMP) support, Intel Smart Response Technology, AMD 3-way CrossFireX technology support, ESD Protection, Clear CMOS Button, MSI Gaming Device Port, Killer DoubleShot Pro, MSI Mystic Light, MSI Steel Armor, Game Boost, LAN Protect, 3D printing friendly, Intel Optane Memory Ready, MSI Audio Boost 4 RPO, Nahimic 2 Sound Technology, M.2 Shield FROZR, MSI Military Class VI, TURBO SOCKET
I/O back plate, 2 aerials, case badge, cable labels, RGB (RGBW) LED strip extension cable, 3D printing mount package
4 x Serial ATA cable , 1 x SLI bridge
Software Included
Drivers & Utilities, MSI Command Center, RAMdisk, MSI Live Update 6, MSI Gaming Hotkey, MSI Gaming LAN Manager, MSI CPU-Z, MSI X-BOOST
30.5 cm
24.4 cm
