MSI RTX 2070 Ventus GP 8GB Graphics Card
Quicklinx: FVC6WS00 Mfr#: RTX 2070 VENTUS GP
This revolutionary architecture, combined with the GeForce RTX platform, fuses together real-time ray tracing, artificial intelligence, and programmable shading. You've never created and enjoyed games like this before. Every detail counts when it comes to creating the ultimate thermal design, which is why VENTUS uses a premium thermal compound to make sure it outlives the competition.
  • NVIDIA Turing Architecture
  • Real-time ray tracing in games
    Ray tracing is the definitive solution for lifelike lighting, reflections, and shadows, offering a level of realism far beyond what's possible using traditional rendering techniques. NVIDIA Turing is the first GPU capable of real-time ray tracing.
  • Advanced performance
    GeForce RTX gaming GPUs come loaded with next-generation GDDR6 memory, support for DirectX 12 features, and more. This is graphics reinvented.
  • Premium design
    A fresh dual fan design, VENTUS proudly displays its industrial shapes in neutral colors to fit any build.
  • TORX Fan 2.0
    Using two of the award-winning TORX Fans 2.0, MSI VENTUS graphics cards provide years of top-notch cooling performance.
  • Direct contact heat pipes
    Up to 6mm thick copper heat pipes at the bottom maximize heat transfer.
  • Premium thermal compound
MSI GeForce RTX 2070 VENTUS GP - graphics card - GF RTX 2070 - 8 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce RTX 2070 - up to
8 GB GDDR6
Boost Clock
1620 MHz
CUDA Cores
2304
Memory Interface
256-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
3 x DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5
4.2 cm x 23.2 cm x 12.7 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Boost Clock
1620 MHz
CUDA Cores
2304
VR Ready
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
MSI Afterburner, NVIDIA Adaptive Vertical Sync, NVIDIA G-Sync ready, Torx 2.0 Fans, Real-Time Ray Tracing, NVIDIA Turing GPU architecture, Nvidia GeForce RTX VR Ready, HDCP
Size
8 GB
GDDR6 SDRAM
Bus Width
256-bit
Required Power Supply
550 W
Additional Requirements
8 pin PCI Express power connector
175 Watt
Software Included
MSI Afterburner
DisplayPort 1.4, HDCP 2.2
4.2 cm
23.2 cm
12.7 cm
728 g
Shipping Weight
1.161 kg
