This notebook's processor requires lower power consumption, but delivers better performance than before. The amazing graphics card brings extreme graphics performance to notebooks. It delivers powerful performance and outstanding efficiency in a lightweight and portable device for exquisite artwork designs and lifelike multimedia entertainment. MSI True Color technology ensures that each panel in a MSI notebook features fine precision in color. Hence, each color is delivered with high standard precision in detail, guaranteeing excellent color fidelity for many use applications.
With the Matrix Display, you can build the multi-display working or multimedia environment. Work or fun, it is possible to have both at the same time with just one MSI Prestige notebook. Inspired by boutique fashion and high-precision instruments, the MSI Prestige series is simple yet sophisticated - with silky metallic exterior design and the light backlit keyboard in the interior.
Powerful processor
The processor requires lower power consumption, but delivers better performance than before. -
Advanced desktop performance made portable
The amazing graphics card brings extreme graphics performance to notebooks. It delivers powerful performance and outstanding efficiency in a lightweight and portable device for exquisite artwork designs and lifelike multimedia entertainment. -
MSI True Color technology guarantees that each panel in a MSI notebook features fine precision in color. Hence, each color is delivered with high standard precision in detail, guaranteeing excellent color fidelity for many use applications. -
Matrix Display technology
As a designer or business elite, it is a must to possess multi-task ability. However, it is also extremely important to relax completely after work to keep a balanced life. With the Matrix Display, you can build the multi-display working or multi-media environment. Work or fun, it is possible to have both at the same time with just one MSI Prestige notebook. -
Silky metallic cover
Inspired by boutique fashion and high-precision instruments, the MSI Prestige series is simple yet sophisticated - with silky metallic exterior design and the light backlit keyboard in the interior. -
Nahimic Audio Enhancer
Nahimic enhances sound quality and precision, audio inputs are therefore transformed into vivid-like ones. Build your own entertainment corner and enjoy the immersive virtual sound in high definition with one laptop and with just one simple click. -
Sound by Dynaudio
Dynaudio Premium Sound technology delivers an authentic sound experience by boosting power amplitude. Any high quality stereo source is transformed into true-to-life, multi-channel sound. No need to purchase extra speakers, wires or speaker stands to appreciate room-filling sound. -
Audio Boost technology
The MSI Audio Boost design enhances the output sound detail and sound stage. The gold flash audio jack provides stable sound transmission (reduced obstruction) and works in conjunction with the optimized headsets AMP (Audio Power Amplifier) design, with low noise and low distortion characteristics, to greatly enhance headphone performance and faithfully reproduce each acoustic detail. -
SHIFT - boost performance under controlled noise and temperature
The exclusive MSI SHIFT technology pushes system to the extreme while minimizing noise and temperature. Switch between two other profiles sport and comfort to reach balance between system performance and comfortable user experience. -
Cooler Boost 3 - better cooling solution
The Cooler Boost 3 technology creates a split thermal solution for the MSI Prestige series by utilizing a total of 4 heat pipes, 2 dedicated for graphics card and 2 for processor and dual fans. This thermal solution significantly reduces system temperature by optimizing thermal dissipation with dual fans and pushing heat outside through 4 vents. Cooler Boost 3 offers optimum cooling and maintains a stable and low temperature system even after long sessions of the highest loading.
- MSI PX60 6QD 065UK - 15.6" - Intel Core i7 - 6700HQ - 8 GB RAM - 1 TB HDD
- Product Type
- Notebook
- Operating System
- Win 10 Pro
- Processor
- Intel Core i7 (6th Gen) - 6700HQ / 2.6 GHz, up to 3.5 GHz / 6 MB Cache
- Memory
- 8 GB DDR4
- Storage
- 1 TB HDD / 7200 rpm
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD
- Graphics
- NVIDIA GeForce GTX 950M
- Video Memory
- 2 GB GDDR5 SDRAM
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 6-cell
- Silky silver
- 39 cm x 26.6 cm x 2.005 cm
- 2.1 kg
- Environmental Standards
- - EPEAT Climate+
- Limited warranty - 2 years
- Product Type
- Notebook
- Operating System
- Windows 10 Pro
Processor / Chipset
- CPU
- Intel Core i7 (6th Gen) 6700HQ / 2.6 GHz
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Chipset
- Mobile Intel HM170
- Hyper-Threading Technology, integrated memory controller, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz / PC4-17000
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
Storage
- Main Storage
- 1 TB HDD SATA 6Gb/s / 7200 rpm
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Colour Gamut
- 100% sRGB, 94% NTSC
- Anti-glare, TrueColor, WideView, MSI Matrix Display
Audio & Video
- Graphics Processor
- Video Memory
- 2 GB GDDR5 SDRAM
- Camera
- Yes - 1080p
- Sound
- Four speakers, microphone
- Audio Features
- Output: Dynaudio Premium Sound Technology, MSI Audio Boost, Nahimic sound technology
Input
- Keyboard, touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 3165 - M.2 Card
- Network Interface
- Gigabit Ethernet
- Technology
- 6-cell
AC Adapter
- Output
- 120 Watt
Connections & Expansion
- Interfaces Details
- LAN , Microphone input , Headphone output , 2 x USB 3.0 , HDMI , Mini DisplayPort , USB-C
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
- Silky silver
- Case Material
- Metal
- Cooler Boost 3 technology, MSI SHIFT Technology
- Included Accessories
- Power adapter
- 2.1 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
