MSI Prestige 16 AI Studio RTX4050 Core Ultra 7 32GB 1TB
Quicklinx: HV9WWS00 Mfr#: 9S7-15A211-035
Screen Size: 16in
Processor Model: 155H
Operating System: Windows 11 Home
Hard Drive Capacity: 1TB
Graphics: NVIDIA GeForce RTX 4050 / Intel Arc Graphics
  • IEEE 802.11n
£1,329.79 ex VAT
£1,595.74 inc VAT
Reimagine productivity with AI. The Prestige 16 AI Studio B1V takes premium mobile performance, brilliant display, slim body and high battery efficiency to the next stage. It delivers exceptional performance whether you are creating, planning or traveling - this AI business laptop allows you to work on-the-go.
  • Reliable and beautiful
    Slim and durable, the Prestige 16 AI Studio B1V is crafted with a magnesium-aluminum chassis. Using Thixomolding with ATT (Advanced Thixomolding Technology), optimizes the mold injection process to achieve a seamless metal body: redefining strength, durability, and quality with the Prestige Series.
  • Powered by AI
    The Prestige 16 AI Studio B1V has advanced certification and comes powered by a great processor, making intensive computation seem easy and efficient. The NPU also powers more workloads; it is a great choice to accelerate AI programs for long-sustained, power moderate, intensive applications. Extend your productivity with a powerful and reliable performance on-the-go.
  • Your ideas, accelerated by NVIDIA Studio
    Creativity that's all in. NVIDIA Studio is your creative advantage with state-of-the-art RTX GPUs that power top creative apps. Ray tracing delivers hyper-realistic graphics, and the Studio suite of AI-assisted tools take ideas from concept to completion, faster. Studio Drivers provide maximum reliability so you can focus on your next big idea.
  • Developer tools
    Boost productivity with accelerated performance in machine learning algorithms, data processing, and other compute-intensive coding tasks. Enjoy GPU-accelerated workflows for training and deploying AI models, exclusive tools, containers, and SDKs, and open source models optimized for RTX.
  • MSI AI Artist
    MSI AI Engine is able to detect user scenarios and automatically adjust hardware settings to achieve excellent performance. With simple AI tuned modes and resources, you can focus on the important things like creating, work and entertainment. Thanks to AI Noise Cancellation Pro and Spatial Array Microphone (3 mics) setup, you still can enjoy crystal clear sound even in a noisy environment.
  • Wireless reimagined
    The Wi-Fi 7 network speed packs more data into each transmission, making it significantly faster. Its potential maximum data rate is nearly 5.8 Gbps, which is faster than the 2.4 Gbps speeds with Wi-Fi 6/6E, making it easy to stream high-quality video, downloading large files in less time and accomplishing your tasks at breathtaking speeds.
  • Dynamic colors, brighter idea
    Visualize your creatives through a vibrant OLED panel. Producing pure blacks and bright whites, its high-contrast colors bring both video and image to life. The 16:10 aspect ratio gives you the power for a more spacious workspace and a comfortable visual experience especially during long use.
  • All day, everyday
    Don't worry about forgetting to take your adapter to the next available wall outlet. This device has a large battery capacity of 99.9 Wh, which adapts to the way you work and ensures you can keep going for longer.
  • Charge and go
    The Prestige 16 AI Studio B1V supports 140 W PD 3.1 fast charging. The maximum charging voltage has been updated from 20 V to 28 V, which ensures that your mobile devices stay productive and powered even when you're busy with work and don't have much time to charge. It offers a highly portable and efficient fast charging solution compared to normal daily laptops.
  • Keep it cool
    With its advanced MSI Cooler Boost 3 technology, this laptop features a dual thermal system designed for next-generation extreme performance. It includes dual fans and three heat pipes to effectively dissipate heat for both the processor and graphics, resulting in an enhanced experience while pursuing ultimate performance.
  • Connect all your needs
    No matter what you need, the Prestige 16 AI Studio B1V offers three-sided ports including USB-A, USB-C, an SD card reader, HDMI, and Thunderbolt 4. It always keeps you connected and productive, allowing you to enjoy an ultrathin and lightweight carry without any compromise.
MSI Prestige 16 AI Studio B1VEG-035UK - AI Ready - 16" - Intel Core Ultra 7 - 155H - 32 GB RAM - 1 TB SSD
Notebook - AI Ready
Operating System
Win 11 Home
Intel Core Ultra 7 (Series 1) - 155H / 1.4 GHz, up to 4.8 GHz / 24 MB Cache
32 GB LPDDR5 (provided memory is soldered)
Storage
1 TB SSD - NVMe
Display
16" 2560 x 1600 / QHD+
Graphics
Video Memory
6 GB GDDR6 SDRAM
Keyboard Backlight
Yes (white)
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac/ax/be, Bluetooth 5.4
4-cell - up to 14 hours
Security
Fingerprint reader
Stellar grey
35.84 cm x 25.44 cm x 1.895 cm
1.6 kg
Limited warranty - 1 year
Notebook - AI Ready
Operating System
Windows 11 Home
Processor / Chipset
CPU
Intel Core Ultra 7 (Series 1) 155H / 1.4 GHz
Max Turbo Speed
4.8 GHz
Number of Cores
16-core
Cache
24 MB
Intel Smart Cache
RAM
32 GB (provided memory is soldered)
LPDDR5 SDRAM
Speed
6400 MHz
Rated Speed
6400 MHz
Storage
Main Storage
1 TB SSD M.2 PCIe - NVM Express (NVMe)
Display
16"
Resolution
2560 x 1600 (QHD+)
Widescreen
Image Aspect Ratio
16:10
Colour Gamut
100% DCI-P3
IPS-level
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
6 GB GDDR6 SDRAM
Video System Features
Dynamic Boost
Camera
Yes - 1080p
Frame Rate
30 frames per second
Camera Features
Privacy shutter, IR camera, Windows Hello, 3D Noise Reduction
Sound
Stereo speakers, microphone
Input
Keyboard, touchpad
Keyboard Backlight
Yes (white)
Numeric Keypad
Communications
Wireless
Wireless Controller
Killer Wi-Fi 7 BE1750
4-cell lithium polymer
99.9 Wh
Run Time
Up to 14 hours
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Output
140 Watt, 28 V, 5 A
Connections & Expansion
Interfaces Details
USB 3.2 Gen 2 , USB-C 3.2 Gen 2 (supports DisplayPort Alt Mode) (Power Delivery) , Headphone/microphone combo jack , HDMI , USB-C (supports Thunderbolt 4, DisplayPort Alt Mode) (Power Delivery)
Memory Card Reader
Yes (SD Card)
Software
Software Included
Tobii Aware, MSI Center
Stellar grey
Case Material
Magnesium-aluminum alloy
Security
Fingerprint reader
Fingerprint-resistant coating, Cooler Boost 3 technology, MIL-STD-810H tested, MSI AI engine
USB-C power adapter
1.6 kg
Screen Size: 16in
Brand: MSI
Price Range Ex VAT: £1000 - £1500
