Gaming intelligence
To improve the users' experience, MSI designed a series of smart software based on years of professional experience in research and development of eSports and an understanding of the needs of players. Through smart gaming technologies provided by MSI, including SoundTune, Optix Score, players can have a better gaming experience. -
KVM
With KVM function, you can control multiple devices with one set of joystick, keyboard or mouse through the MSI gaming monitor. -
Sound Tune
Eliminating all obstacles to communication, the MSI monitor eliminates background noise through AI calculations and helps communication between teammates with more refined sound quality to achieve the best teamwork for the final victory. -
MSI Console Mode
For PS5, MSI designed an exclusive Console Mode for the consoles, which can automatically accept 4K signals on QHD monitor, and support HDR simultaneously. This gives you the best gaming experiences and allows you to enjoy console games even with a QHD monitor. -
Night Vision AI
Whether your entire screen is dark, or just a few portions have heavy shadows. Let the world's first smart black tuner brighten your day by bringing out the fine details in dark areas. -
Optix Scope
Snipe and kill your opponents before they can react. The built-in aim magnifier provides multi-stage zooming with shortcut keys to quickly switch the magnification. The screen can maintain the operation so that no matter what weapon is used, it can become a sniper rifle and attack enemies from miles away. -
Smart cross hair
Through AI calculation, the aim dot automatically changes color, making it visible at any time. If the color of the aim dot overlaps with the background color, it will be problematic for aiming. The MSI monitor uses AI to calculate the color around the red dot and automatically adjusts it to a color that contrasts with the surrounding colors to ensure that you can always see your aim dot. -
Smart brightness
The MSI Gaming monitor can automatically detect the ambient light in the room and adjust the screen brightness to the appropriate level. -
True color - width matters
The MSI 21:9 ultrawide Gaming monitor is built to step your game up by giving you extra POV to enhance your peripheral vision. With a 3440x1440 resolution and a 21:9 aspect ratio, enjoy the latest AAA title games the way it was meant with gorgeous details that span across your entire peripheral view. -
See every moment at its clearest
Rapid boost display provides gamers with an ultra-fast response time and refresh rate, which will significantly reduce monitor blur occurrence. The crystal clear image will certainly give you a competitive edge for precise decisions in fast-moving games. -
The perfect refresh rate
Challenge any game without screen tearing, stuttering, flicker, or artifacts. G-SYNC compatible dynamically matches the refresh rate of the display to the frame rate of the GPU. -
HRD400 - the most vivid display
The MSI Gaming monitor is equipped with HDR technology that can produce images with more details, wider range of colors, and look more similar to what is seen by the human eye when compared to traditional monitor. -
HDR - true color
The MSI monitor have more gamut coverage compared to general monitors. Gameplay colors and details will look more realistic and refined, to push immersion to its limits. -
Mystic light - gaming OSD APP 2.0
Easily configure your gaming monitor settings with the Gaming OSD (On Screen Display) app. Effortlessly change your settings with your Keyboard and Mouse and program hotkey options to quickly switch settings in-between games. -
Refresh rate optimization
Using keyboard & mouse to optimize monitor OSD function in a very easy way. -
True Color Sync
Maintain the same color display among MSI devices. A laptop for work can maintain the same color performance when connected to a monitor at home with True Color Sync. Maintain the same color display and avoid color differences between devices. -
Firmware update
MSI Gaming monitor can update the firmware through a USB connector, which is simple and easy to use. This allows users to update the firmware on their own at any time when the latest version is released by MSI. This ensures that the screen is always in the best-optimized state. -
Personalize your gaming rig
With MSI Mystic Light, the MSI gaming monitor lights provide a soft ambient light that can easily be synced with any other Mystic Light enabled gaming product. Select any of the colors from the palette using your smartphone or the Mystic Light App to match your system style to your taste. Or just turn on gaming echo, letting your monitor back light dance to music you play on the computer. -
Accessorize your experience
The built-in mouse bungee helps you organize your mouse cable and prevents the excess cable from interfering with your path to victory. -
Tailored for the perfect fit
The MSI Gaming monitor is built to make you as comfortable as possible while gaming. Through adjustments of tilting, lowering and raising, and swiveling, you can easily change the position of the monitor for maximum ergonomics and optimum viewing experiences. -
Universal Type-C connection
The MSI gaming monitor supports USB Type-C connection, allowing you to power your devices (up to 15W) and effortlessly connect to any device. -
MSI heard you like workspace
The MSI Gaming Monitor is specially designed for mobile phones with an 18:9 PBP display area and is fully capable of presenting a mobile phone screen and keep it close to 16:9 for computer devices. It is also possible to use the mobile phone and the computer at the same time, greatly optimizing the streaming and work functions. -
Anti - flicker
Erase the amount of screen flicker. -
5-way navigator control
Control your monitor with an easier way. -
Less Blue Light
Reduce eyestrain and fatigue with Less Blue Light technology. -
USB Hub
Connect your USB device more convenient. -
Internal adaptor
No additional adapter needed. -
Frameless design
With the narrow bezel, you will not even notice the monitor.
- MSI Optix MPG341QR - LED monitor - 34" - HDR
- LED-backlit LCD monitor - 34"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/623434
- Energy Class
- Class G
- Adaptive-Sync Technology
- NVIDIA G-SYNC Compatible
- 5-way joystick, KVM Switch, USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- UWQHD 3440 x 1440 (DisplayPort: 144 Hz, HDMI: 100 Hz, USB-C: 144 Hz)
- Pixel Pitch
- 0.2325 mm
- Brightness
- 550 cd/m²
- Contrast Ratio
- 1000:1 / 100000000:1 (dynamic)
- Response Time
- 1 ms
- Gaming
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 88.2% Adobe RGB (CIE 1976), 91.5% DCI-P3 (CIE 1976), 122.5% sRGB (CIE 1976)
- Input Connectors
- 2xHDMI, DisplayPort, USB-C
- Height, swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 100-240 V (50/60 Hz)
- 81.74 cm x 25.226 cm x 42.27 cm
- 9.38 kg
- DisplayPort 1.4, CIE1976
- Display Type
- Energy Class
- Class G
- Energy Class (HDR)
- Class G
- Diagonal Size
- 34"
- Built-in Devices
- KVM Switch, USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- Pixel Pitch
- 0.2325 mm
- Brightness
- 550 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- 1 ms
- Vertical Refresh Rate
- 48 - 144 Hz
- Horizontal Refresh Rate
- 72 - 216 kHz
- Gaming
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Picture by picture, Crosshair Display, Wide Colour Gamut, MSI Anti-Flicker, frameless bezel design, Picture-in-Picture, Low Blue Light technology, night vision mode, MSI Mystic Light, 10-bit(8-bit + FRC) Colour Depth, Rapid Boost, mouse bungee, HDR400
- 81.74 cm x 25.226 cm x 42.27 cm - with stand
- 9.38 kg
Input
- 5-way joystick
- DisplayPort 1.4 , 2 x HDMI , USB-C/DisplayPort Alt Mode , USB 2.0 upstream (Type B) , 2 x USB 2.0 downstream , Headphones
Mechanical
- Tilt Angle
- -5/20
- Swivel Angle
- 60
- Height Adjustment
- 100 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption SDR (On mode)
- 39.9 kWh/1000h
- Power Consumption HDR (On mode)
- 75 kWh/1000h
- Power Consumption (Typical)
- 40 Watt
- Included Software
- MSI Gaming OSD App
- Dimensions & Weight Details
- With stand - width: 81.74 cm - depth: 25.226 cm - height: 42.27 cm - weight: 9.38 kg , Without stand - width: 81.74 cm - depth: 6.524 cm - height: 37.42 cm
- Shipping Width
- 84.7 cm
- Shipping Depth
- 17.1 cm
- Shipping Height
- 64 cm
- Shipping Weight
- 13.8 kg
