MSI Optix MPG321UR-QD eSports Gaming Monitor
Quicklinx: GZ92WS00 Mfr#: 9S6-3DC07T-009
If only you could combine the crisp details of a 4K gaming experience with the fluidity of a high refresh rate monitor. Well, MSI's Optix MPG321UR-QD 4K 144Hz Monitor does precisely that. And does it well.
The amount of screen real estate that a 4K monitor brings to the table is unreal for many, especially on a large 32-inch monitor like the MPG321UR-QD. It features a top-notch IPS panel that delivers the much-needed combination of accurate colors, wide viewing angles, and exceptional brightness levels.
With the launch of this 4K 144Hz monitor that features an excellent response time of just 1ms (GTG), competitive gamers can now finally think of making the switch to the much-coveted 4K resolution. It gives you much more information while keeping your gameplay as fluid as you're used to as long as your Gaming PC can deliver enough performance.
While a regular KVM gives your peripherals the ability to control multiple systems, MSI takes it a step further with the inclusion of KVM 3.0 on this 4K 144Hz gaming monitor. In addition to just managing several devices with a single keyboard, mouse, and game controller, you can now also transfer files between them!
Console users can rejoice, too, as the Optix MPG321UR-QD also features the latest HDMI 2.1 port. It allows you to enjoy the full, unbridled 4K 120Hz experience even when gaming on a new-generation console.
MSI Optix MPG321UR-QD - LED monitor - 4K - 32" - HDR
LED-backlit LCD monitor - 32"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/802784
Energy Class
Class G
Adaptive-Sync Technology
NVIDIA G-SYNC Compatible
5-way joystick, USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 144 Hz
Pixel Pitch
0.1845 mm
Brightness
600 cd/m²
Contrast Ratio
1000:1
HDR Capable
DisplayHDR 600
Response Time
1 ms (MPRT)
Gaming
Colour Support
1.07 billion colours
Colour Gamut
99% Adobe RGB, 97% DCI-P3 (CIE 1976), 143% sRGB (CIE 1976)
Input Connectors
2xHDMI, DisplayPort, USB-C
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare
Voltage
AC 100-240 V (50/60 Hz)
72.71 cm x 25.18 cm x 48.22 cm
10.1 kg
DisplayPort 1.4a
Display Type
Energy Class
Class G
Energy Class (HDR)
Class G
Diagonal Size
32"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1845 mm
Brightness
600 cd/m²
Contrast Ratio
1000:1
HDR Certification
DisplayHDR 600
Colour Support
Colour Gamut
Response Time
1 ms (MPRT)
Vertical Refresh Rate
47 - 144 Hz
Horizontal Refresh Rate
180 - 317 kHz
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Frameless, Wide Colour Gamut, MSI True Colour Technology, MSI Anti-Flicker, Quantum Dot Technology, Low Blue Light technology, night vision mode, MSI Mystic Light, Rapid Boost, mouse bungee
10.1 kg
Input
5-way joystick
DisplayPort 1.4a , 2 x HDMI , Microphone , Headphones , 6 x USB 2.0 , 3 x USB 2.0 (Type B) , USB-C upstream/DisplayPort Alt Mode (KVM option)
Mechanical
Tilt Angle
-5/+20
Swivel Angle
60
Height Adjustment
100 mm
VESA Mounting Interface
100 x 100 mm
DisplayPort 1.4a
Security Slot Type
Kensington security slot
Input Voltage
41.9 kWh/1000h
Power Consumption HDR (On mode)
65 kWh/1000h
Shipping Width
97.5 cm
Shipping Depth
18.1 cm
Shipping Height
55 cm
Shipping Weight
14.1 kg
