The MAG series was born through rigorous quality testing and designed to be a symbol of sturdiness and durability. Focused on providing the perfect user experience, the MAG series has a simple installation process coupled with a friendly user interface making it the perfect choice for entry level gamers.
See every moment at its clearest
Rapid IPS display provides gamers with an ultra-fast 1 ms GTG response time, which will significantly reduce monitor blur occurrence. The crystal clear image will certainly give you a competitive edge for precise decisions in fast-moving games. -
Width matters
The MSI Optix MAG301RF 21:9 ultrawide Gaming monitor is built to step your game up by giving you extra POV to enhance your peripheral vision. With a 2560 x 1080 resolution and a 21:9 aspect ratio, enjoy the AAA title games the way it was meant with gorgeous details that span across your entire peripheral view. -
Age crossing technological breakthrough
The liquid crystal molecules of Rapid IPS display rotate as fast as the tornado. With the speed going up to 4x faster than normal liquid crystal molecules, the response time can be shortened to 1 ms GTG (gray to gray) to eliminate monitor blur and provide crystal clear images. -
Perfection for any refresh rate
Take on any game without tearing, stuttering, flicker, or artifacts. G-SYNC compatible dynamically matches the refresh rate of the display to the frame rate of the GPU. Unlike other solutions, its unrestricted refresh rate supports from zero Hertz up to the maximum supported by the LCD panel - so you can count on exceptional performance in every game. -
This is color
Optix series gaming monitor is equipped with an IPS panel that produces no image distortion and minimum color shifts when viewed from different angles. Additionally, the IPS panel will offer clear images and instantly optimize screen color and brightness to ensure that you enjoy every scene at its best. -
Vivid display
The Optix series gaming monitor is equipped with HDR technology which produces images with more details, a wide range of color, and appears more similar to what is seen by the human eye when compared to traditional monitors. -
From edge to edge
Enjoy better continuity between screens while playing games, working, or general computing. -
178 degrees of wide viewing angle
By having a large viewing angle, MSI gaming monitors has more leeway for placing your monitor in your setup without giving up the optimal viewing experience. Colors and details will stay sharp at more angles compared to other monitors with less viewing angles.
- MSI Optix MAG301RF - LED monitor - 30"
- LED-backlit LCD monitor - 30"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/442962
- Energy Class
- Class G
- Native Resolution
- 2560 x 1080
- Display Type
- Energy Class
- Class G
- Energy Class (HDR)
- Class G
- Diagonal Size
- 30"
- Native Resolution
- 2560 x 1080
- Power Consumption SDR (On mode)
- 29 kWh/1000h
- Power Consumption HDR (On mode)
- 37 kWh/1000h
