MSI Optix MAG281URF eSports Gaming Monitor
Quicklinx: GZ8TWS00 Mfr#: 9S6-3CC8GQ-016
The MAG series was born through rigorous quality testing and designed to be a symbol of sturdiness and durability. Focused on providing the best user experience, the MAG series has a simple installation process coupled with a friendly user interface making it the best choice for entry level gamers.
Visualize your victory with MSI Optix MAG281URF esports gaming monitor. Equipped with a 3840x2160 4K, 1ms response time panel, Optix MAG281URF will give you the competitive edge you need to take down your opponents. Enjoy extremely smooth, tear-free gameplay with built-in Adaptive sync technology. Make sure you can hit your mark with all the latest technologies built-in the MSI esports gaming monitors for competitive play.
  • The beauty is in the details
    MSI gaming monitor feature a UHD panel that supports resolution up to 3840x2160. This 16:9 panel allows gamers to examine bigger game scenes compared to other traditional FHD panels, and provide an immersive gaming experience.
  • See every moment at its clearest
    Rapid IPS display provides gamers with an ultra-fast GTG response time, which will significantly reduce monitor blur occurrence. The crystal clear image will certainly give you a competitive edge for precise decisions in fast-moving games. MMSI's esports gaming monitor has a high-speed refresh rate, eliminating screen delay time and presenting an extremely smooth screen presentation. With a fast response time, users can respond accordingly in games such as first-person shooters and racing games and quickly win with one click.
  • High refresh rate and fast response time
    Optix monitors are equipped with a high refresh rate and quick response time IPS panel which has the most benefit in fast moving game genres such as first person shooters, fighters, racing sims, real-time strategy, and sports. These types of games require very fast and precise movements, which an ultra-high refresh rate and fast response time monitor will put you ahead of your competition.
  • Blue light reduction
    As a game lover, MSI understands how unbearable is that when your screen becomes yellow after using less blue light. Less blue light premium is using a hardware solution to reduced light emissions in the blue-violet segment of the blue light spectrum without any color or picture quality sacrifice. EYESAFE certificated hardware solution perfectly reduces harmful light-emitting wavelengths and maintains color gamut and color temperature to display flawless picture quality and gaming experience.
  • The perfect refresh rate
    Challenge any game without screen tearing, stuttering, flicker, or artifacts. G-SYNC compatible dynamically matches the refresh rate of the display to the frame rate of the GPU.
  • Optix scope
    Snipe and kill your opponents before they can react. The built-in aim magnifier provides multi-stage zooming with shortcut keys to quickly switch the magnification. The screen can maintain the operation so that no matter what weapon is used, it can become a sniper rifle and attack enemies from miles away.
  • Smart cross hair
    The aim dot automatically changes color, making it visible at any time. If the color of the aim dot overlaps with the background color, it will be problematic for aiming.
  • Personalize your gaming rig
    With MSI Mystic Light, the Optix MAG series gaming monitor lights provide a soft ambient light that can easily be synced with any other Mystic Light enabled gaming product. Select any of the colors from the palette using your smartphone or the Mystic Light App to match your system style to your taste. Or just turn on gaming echo, letting your monitor back light dance to music you play on the computer.
  • Universal type-c connection
    This MSI Optix gaming monitor supports USB Type-C connection, allowing you to power your devices and effortlessly connect to any device.
  • Tailored for the perfect fit
    The MSI Optix Gaming monitor is built to make you as comfortable as possible while gaming. Through adjustments of tilting, lowering and raising, and swiveling, you can easily change the position of the monitor for maximum ergonomics and optimum viewing experiences.
MSI Optix MAG281URF - LED monitor - 4K
LED-backlit LCD monitor
Adaptive-Sync Technology
NVIDIA G-SYNC Compatible
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160
Contrast Ratio
100000000:1 (dynamic)
Display Position Adjustments
Tilt
Display Type
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160
Contrast Ratio
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Mechanical
Tilt
