Optix monitors use a curved display panel that has a curvature rate of R1500, which is the most comfortable and suitable for a wide range of applications from general computing to gaming. Curved panels also help with gameplay immersion, making you feel more connected to the entire experience.
165Hz refresh rate + 1ms response time
Optix monitors are equipped with a 165Hz refresh rate and 1ms response time VA panel which has the most benefit in fast moving game genres such as first person shooters, fighters, racing sims, real-time strategy, and sports. -
Tear-free, stutter-free, fluid gaming
Gaming shouldn't be a choice between choppy gameplay and broken frames. With MSI Optix series gaming monitors, it doesn't have to be. Get fluid, artifact-free performance at virtually any framerate with AMD FreeSync technology. -
From edge to edge
With a super narrow bezel, enjoy the best immersion possible in the latest games with a multi-monitor 180 degree setup. Enjoy better continuity between screens while playing games, working, or general computing. -
Anti-Flicker technology
Generic monitor displays normally have a flicker-rate of about 200-times per second, which is unnoticeable to the naked eye, but can cause fatigue over time. MSI Anti-Flicker technology provides a very comfortable viewing experience by reducing the amount of flicker. -
178 degrees of wide viewing angle
By having a large viewing angle, MSI gaming monitors has more leeway for placing your monitor in your setup without giving up the optimal viewing experience. Colors and details will stay sharp at more angles compared to other monitors with less viewing angles. -
Blue light reduction
Optix monitors are optimized to produce less amount of blue light displayed by the monitor, so that you can game for longer periods of time without eye-fatigue.
- MSI Optix G32CQ4 - LED monitor - curved - 31.5"
- LED-backlit LCD monitor - 31.5"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/414509
- Energy Class
- Class G
- Curved Screen
- Adaptive-Sync Technology
- AMD FreeSync Premium
- 5-way joystick
- Aspect Ratio
- 16:9
- Native Resolution
- WQHD 2560 x 1440 (DisplayPort: 165 Hz, HDMI: 144 Hz)
- Pixel Pitch
- 0.2724 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1 / 100000000:1 (dynamic)
- Response Time
- 1 ms (MPRT)
- Gaming
- Colour Support
- 16.7 million colours
- Colour Gamut
- 114.8% sRGB, 91.43% DCI-P3
- Input Connectors
- 2xHDMI, DisplayPort
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 100-240 V (50 - 60 Hz)
- 70.94 cm x 24.89 cm x 50.95 cm
- 6.4 kg
- DisplayPort 1.2a, CIE1976
- Display Type
- Energy Class
- Class G
- Diagonal Size
- 31.5"
- Curved Screen
- Yes (1500R)
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2724 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- 1 ms (MPRT)
- Vertical Refresh Rate
- 48 - 165 Hz
- Horizontal Refresh Rate
- 70.56 - 243.38 kHz
- Gaming
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Frameless, Low Blue Light technology, Anti-Flicker
- 6.4 kg
Input
- 5-way joystick
- DisplayPort , 2 x HDMI , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption SDR (On mode)
- 40.9 kWh/1000h
- Power Consumption (Typical)
- 58 Watt
- Shipping Width
- 88.3 cm
- Shipping Depth
- 19.5 cm
- Shipping Height
- 54 cm
- Shipping Weight
- 9.1 kg
