MSI Optix G27CQ4 27" Curved Gaming Monitor
Quicklinx: GZ52WS00 Mfr#: 9S6-3CB01T-016
Optix monitors use a curved display panel that has a curvature rate of 1500R, which is the most comfortable and suitable for a wide range of applications from general computing to gaming. Curved panels also help with gameplay immersion, making you feel more connected to the entire experience.
  • View wider fight better
    Optix G27CQ4 curved gaming monitor features a 27" WQHD panel that supports resolution up to 2560x1440. This 16:9 panel allows gamers to examine bigger game scenes compared to other traditional Full HD panels, and put them ahead of other competitors. Such resolution also allows gamers to multitask with several windows displayed in the same time, providing the efficiency for them to achieve everything they want.
  • Anti-Flicker Technology
    Generic monitor displays normally have a flicker-rate of about 200-times per second, which is unnoticeable to the naked eye, but can cause fatigue over time. MSI Anti-Flicker technology provides a very comfortable viewing experience by reducing the amount of flicker.
  • Blue light reduction
    Optix monitors are optimized to produce less amount of blue light displayed by the monitor, so that you can game for longer periods of time without eye-fatigue.
  • 178 degrees of wide viewing angle
    By having a large viewing angle, MSI gaming monitors has more leeway for placing your monitor in your setup without giving up the optimal viewing experience. Colors and details will stay sharp at more angles compared to other monitors with less viewing angles.
MSI Optix G27CQ4 - LED monitor - curved - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class G
Energy Consumption per Year
57 kWh
Power Consumption (On mode)
32.2 W
Curved Screen
Adaptive-Sync Technology
AMD FreeSync
5-way joystick
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
WQHD 2560 x 1440 (DisplayPort: 165 Hz, HDMI: 144 Hz)
Pixel Pitch
0.2331 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 100000000:1 (dynamic)
Response Time
4 ms (grey-to-grey), 1 ms (MPRT)
Gaming
Colour Support
16.7 million colours (8-bit)
Colour Gamut
115% sRGB, 92% DCI-P3
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
AC 120/230 V (50 - 60 Hz)
61.15 cm x 22.54 cm x 45.79 cm
5.4 kg
VCCI, BSMI, CB, PSE Mark, MEPS, KC, RCM, MSIP, DisplayPort 1.2a, CE/EMC, K-MEPS, CIE1976
3-year warranty
Display Type
Energy Class
Class G
57 kWh
Diagonal Size
27"
Curved Screen
Yes (1500R)
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2331 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
48 - 165 Hz
Horizontal Refresh Rate
70.56 - 243.37 kHz
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Blue light reduction, MSI Anti-Flicker, frameless bezel design, night vision mode
61.15 cm x 22.54 cm x 45.79 cm - with stand
5.4 kg
Input
5-way joystick
DisplayPort , 2 x HDMI , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x DisplayPort cable
Security Slot Type
Kensington security slot
Input Voltage
32.2 W
32.2 kWh/1000h
Power Consumption (Typical)
40 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 61.15 cm - depth: 22.54 cm - height: 45.79 cm - weight: 5.4 kg , Without stand - width: 61.15 cm - depth: 7.59 cm - height: 37.28 cm
Shipping Width
75.6 cm
Shipping Depth
16.8 cm
Shipping Height
47.3 cm
Shipping Weight
9 kg
Limited warranty - 3 years
