MSI Optix G27C6 27" Curved Gaming Monitor
Quicklinx: GZ51WS00 Mfr#: 9S6-3CA91T-036
Visualize your victory with MSI Optix G27C6 Curved Gaming monitor. Equipped with a 1920x1080, 165Hz refresh rate, 1ms response time panel, Optix G27C6 will give you the competitive edge you need to take down your opponents. Built with adaptive sync, Optix G27C6 can match the display's refresh rate with your GPU for ultra-smooth gameplay. Make sure you can hit your mark with all advanced technologies built in the MSI Curved Gaming monitor for competitive play.
  • Curved for your viewing pleasure
    MSI Curved Gaming monitors use a curved display panel that has a curvature rate of R1500, which is comfortable and suitable for a wide range of applications from general computing to gaming. Curved panels also help with gameplay immersion, making you feel more connected to the entire experience.
  • 165Hz refresh rate with 1ms response time
    Optix monitors are equipped with a 165Hz refresh rate and 1ms response time VA panel which has benefit in fast-moving game genres such as first-person shooters, fighters, racing sims, real-time strategy, and sports. These types of games require very fast and precise movements, an ultrahigh refresh rate and fast response time monitor will put you ahead of your competition.
  • Night vision engaged
    Whether your entire screen is dark, or just a few portions have heavy shadows, let the smart black tuner brighten your day by bringing out the fine details in dark areas.
  • True color
    The Optix gaming monitors have more gamut coverage compared to general monitors. Gameplay colors and details will look more realistic and refined, to push immersion to the limits.
  • From edge to edge
    With a super-narrow bezel, enjoy the perfect immersion in the modern games with a multi-monitor 180-degree setup. Enjoy better continuity between screens while playing games, working, or general computing.
  • 178 degrees of wide viewing angle
    By having a large viewing angle, MSI gaming monitors have more leeway for placing your monitor in your setup without giving up the optimal viewing experience, colors and details will stay sharp.
  • Tear-free, stutter-free fluid gaming
    Gaming shouldn't be a choice between choppy gameplay or broken frames. With MSI Optix series gaming monitors, it doesn't have to be. Get fluid, artifact-free performance at virtually any frame rate with AMD FreeSync technology.
  • Anti-Flicker technology
    MSI Anti-Flicker technology provides a very comfortable viewing experience by reducing the amount of flicker.
  • Blue light reduction
    Optix monitors are optimized to produce less amount of blue light displayed by the monitor, so that you can game for longer periods of time without eye fatigue.
  • Gaming modes
    MSI gaming monitors offer several game modes for gamers to choose from. Gamers can choose the mode based on the style of the game to experience great visual effects.
MSI Optix G27C6 - LED monitor - curved - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/407090
Energy Class
Class F
Power Consumption (On mode)
26 W
Curved Screen
Adaptive-Sync Technology
AMD FreeSync Premium
5-way joystick
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 (DisplayPort: 165 Hz, HDMI: 144 Hz)
Pixel Pitch
0.3114 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 100000000:1 (dynamic)
Response Time
4 ms (grey-to-grey), 1 ms (MPRT)
Gaming
Colour Support
16.7 million colours
Colour Gamut
112.8% Rec 709 (CIE 1976), 112.8% sRGB (CIE 1976), 119.9% Rec 709 (CIE 1931), 119.9% sRGB (CIE 1931), 84.9% NTSC (CIE 1931), 88.4% DCI-P3 (CIE 1931), 88.8% Adobe RGB (CIE 1931), 89.8% DCI-P3 (CIE 1976), 96.6% Adobe RGB (CIE 1976), 98.3% NTSC (CIE 1976)
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
AC 100 - 240 V (50 - 60 Hz)
61.15 cm x 21.96 cm x 44.59 cm
4.53 kg
DisplayPort 1.2, CIE1931, CIE1976
3-year warranty
Display Type
Energy Class
Class F
Diagonal Size
27"
Curved Screen
Yes (1500R)
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
48 - 165 Hz
Horizontal Refresh Rate
53 - 183 kHz
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Frameless, blue light reduction, MSI Anti-Flicker, night vision mode, 8-bit Colour Depth, Gaming Mode
4.53 kg
Input
5-way joystick
DisplayPort 1.2 , 2 x HDMI , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
Security Slot Type
Kensington security slot
Input Voltage
26 W
26 kWh/1000h
Power Consumption (Typical)
45 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Shipping Width
69.6 cm
Shipping Depth
16.8 cm
Shipping Height
47.3 cm
Shipping Weight
6.7 kg
Limited warranty - 3 years
