Visualize your victory with MSI Optix G27C6 Curved Gaming monitor. Equipped with a 1920x1080, 165Hz refresh rate, 1ms response time panel, Optix G27C6 will give you the competitive edge you need to take down your opponents. Built with adaptive sync, Optix G27C6 can match the display's refresh rate with your GPU for ultra-smooth gameplay. Make sure you can hit your mark with all advanced technologies built in the MSI Curved Gaming monitor for competitive play.
Curved for your viewing pleasure
MSI Curved Gaming monitors use a curved display panel that has a curvature rate of R1500, which is comfortable and suitable for a wide range of applications from general computing to gaming. Curved panels also help with gameplay immersion, making you feel more connected to the entire experience. -
165Hz refresh rate with 1ms response time
Optix monitors are equipped with a 165Hz refresh rate and 1ms response time VA panel which has benefit in fast-moving game genres such as first-person shooters, fighters, racing sims, real-time strategy, and sports. These types of games require very fast and precise movements, an ultrahigh refresh rate and fast response time monitor will put you ahead of your competition. -
Night vision engaged
Whether your entire screen is dark, or just a few portions have heavy shadows, let the smart black tuner brighten your day by bringing out the fine details in dark areas. -
True color
The Optix gaming monitors have more gamut coverage compared to general monitors. Gameplay colors and details will look more realistic and refined, to push immersion to the limits. -
From edge to edge
With a super-narrow bezel, enjoy the perfect immersion in the modern games with a multi-monitor 180-degree setup. Enjoy better continuity between screens while playing games, working, or general computing. -
178 degrees of wide viewing angle
By having a large viewing angle, MSI gaming monitors have more leeway for placing your monitor in your setup without giving up the optimal viewing experience, colors and details will stay sharp. -
Tear-free, stutter-free fluid gaming
Gaming shouldn't be a choice between choppy gameplay or broken frames. With MSI Optix series gaming monitors, it doesn't have to be. Get fluid, artifact-free performance at virtually any frame rate with AMD FreeSync technology. -
Anti-Flicker technology
MSI Anti-Flicker technology provides a very comfortable viewing experience by reducing the amount of flicker. -
Blue light reduction
Optix monitors are optimized to produce less amount of blue light displayed by the monitor, so that you can game for longer periods of time without eye fatigue. -
Gaming modes
MSI gaming monitors offer several game modes for gamers to choose from. Gamers can choose the mode based on the style of the game to experience great visual effects.
- MSI Optix G27C6 - LED monitor - curved - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/407090
- Energy Class
- Class F
- Power Consumption (On mode)
- 26 W
- Curved Screen
- Adaptive-Sync Technology
- AMD FreeSync Premium
- 5-way joystick
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 (DisplayPort: 165 Hz, HDMI: 144 Hz)
- Pixel Pitch
- 0.3114 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1 / 100000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey), 1 ms (MPRT)
- Gaming
- Colour Support
- 16.7 million colours
- Colour Gamut
- 112.8% Rec 709 (CIE 1976), 112.8% sRGB (CIE 1976), 119.9% Rec 709 (CIE 1931), 119.9% sRGB (CIE 1931), 84.9% NTSC (CIE 1931), 88.4% DCI-P3 (CIE 1931), 88.8% Adobe RGB (CIE 1931), 89.8% DCI-P3 (CIE 1976), 96.6% Adobe RGB (CIE 1976), 98.3% NTSC (CIE 1976)
- Input Connectors
- 2xHDMI, DisplayPort
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 100 - 240 V (50 - 60 Hz)
- Black
- 61.15 cm x 21.96 cm x 44.59 cm
- 4.53 kg
- DisplayPort 1.2, CIE1931, CIE1976
- 3-year warranty
- Display Type
- Energy Class
- Class F
- Diagonal Size
- 27"
- Curved Screen
- Yes (1500R)
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.3114 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 48 - 165 Hz
- Horizontal Refresh Rate
- 53 - 183 kHz
- Gaming
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Frameless, blue light reduction, MSI Anti-Flicker, night vision mode, 8-bit Colour Depth, Gaming Mode
- Black
- 4.53 kg
Input
- 5-way joystick
- DisplayPort 1.2 , 2 x HDMI , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Security Slot Type
- Kensington security slot
- Input Voltage
- 26 W
- Power Consumption SDR (On mode)
- 26 kWh/1000h
- Power Consumption (Typical)
- 45 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- Shipping Width
- 69.6 cm
- Shipping Depth
- 16.8 cm
- Shipping Height
- 47.3 cm
- Shipping Weight
- 6.7 kg
- Limited warranty - 3 years
