MSI Optix G273QF Gaming Monitor
Quicklinx: GZ6FWS00 Mfr#: 9S6-3CA81A-046
Visualize your victory with MSI Optix G273QF esports gaming monitor. Equipped with a fast refresh rate, 1 ms GTG response time panel, Optix G273QF will give you the competitive edge you need to take down your opponents.
  • See every moment at its clearer
    Rapid IPS display provides gamers with an ultrafast 1 ms GTG response time, which will significantly reduce monitor blur occurrence. The crystal-clear image will certainly give you a competitive edge for precise decisions in fast-moving games.
  • Age crossing technological breakthrough
    The liquid crystal molecules of Rapid IPS display rotate as fast as the tornado. With the speed going faster than normal liquid crystal molecules, the response time can be shortened to 1 ms GTG to eliminate monitor blur and provide crystal clear images.
  • View wider, fight better
    The Optix gaming monitor features the WQHD panel. This panel allows gamers to examine bigger game scenes compared to other traditional Full HD panels, and put them ahead of other competitors.
  • This is color
    Optix series gaming monitor is equipped with the IPS panel that produces no image distortion and minimum color shifts when viewed from different angles. Additionally, the IPS panel will offer clear images and instantly optimize screen color and brightness to ensure that you enjoy every scene at its best.
  • 165 Hz refresh rate + 1 ms GTG response time
    The Optix monitor is equipped with the 165 Hz refresh rate and 1 ms GTG response time panel which has the benefit in fast moving game genres such as first-person shooters, fighters, racing sims, real-time strategy, and sports. This type of games requires very fast and precise movements, which an ultrahigh refresh rate and fast response time monitor will put you ahead of your competition.
  • Night vision engaged
    Whether your entire screen is dark, or just a few portions have heavy shadows. Let the smart black tuner brighten your day by bringing out the fine details in dark areas.
  • Tailored for the perfect fit
    The MSI Optix gaming monitor is built to make you as comfortable as possible while gaming. Through adjustments of tilting, you can easily change the position of the monitor for maximum ergonomics and optimum viewing experiences.
  • From edge to edge
    With a super-narrow bezel, enjoy better immersion with a multimonitor 180-degree setup. Enjoy better continuity between screens while playing games, working, or general computing.
  • Anti-Flicker technology
    MSI Anti-Flicker technology provides a very comfortable viewing experience by reducing the amount of flicker.
  • Blue light reduction
    The Optix monitor is optimized to produce less amount of blue light displayed by the monitor, so that you can game for longer periods of time without eye-fatigue.
MSI Optix G273QF - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/397299
Energy Class
Class G
Power Consumption (On mode)
32 W
5-way joystick
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
WQHD 2560 x 1440 (DisplayPort: 165 Hz, HDMI: 144 Hz)
Pixel Pitch
0.2331 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Gaming
Colour Support
16.7 million colours
Colour Gamut
125% sRGB, 93% DCI-P3
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
AC 120/230 V (50 - 60 Hz)
61.49 cm x 22.838 cm x 44.46 cm
4.5 kg
TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification, DisplayPort 1.2, CIE1976
3-year warranty
Display Type
Energy Class
Class G
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2331 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
48 - 165 Hz
Horizontal Refresh Rate
90.9 - 242.4 kHz
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Frameless, game mode, blue light reduction, NVIDIA G-SYNC compatible, Wide Colour Gamut, MSI Anti-Flicker, HDR Ready technology, night vision mode, 10-bit(8-bit + FRC) Colour Depth
4.5 kg
Input
5-way joystick
DisplayPort 1.2 , 2 x HDMI , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
Security Slot Type
Kensington security slot
Input Voltage
32 W
32 kWh/1000h
Power Consumption (Typical)
32 Watt
Shipping Width
74.5 cm
Shipping Depth
22.5 cm
Shipping Height
49 cm
Shipping Weight
7.5 kg
Limited warranty - 3 years
