MSI Optix G242 23.8" Full HD Gaming Monitor
Quicklinx: H11DWS00 Mfr#: 9S6-3BA41T-029
Visualize your victory with MSI Optix G242 esports gaming monitor. Equipped with a 144Hz refresh rate, 1ms response time IPS panel, Optix G242 will give you the competitive edge you need to take down your opponents. Enjoy extremely smooth, tear-free gameplay with built-in NVIDIA G-Sync compatible technology when paired with a compatible NVIDIA graphics card.
  • IPS panel
    Optix series monitor is equipped with an IPS panel that produces no image distortion and minimum color shifts when viewed from different angles. Additionally, the IPS panel will offer clear images and instantly optimize screen color and brightness to ensure that you enjoy every scene at its best.
  • 144Hz refresh rate and 1ms GTG response time
    Optix monitors are equipped with a 144Hz refresh rate and 1ms response time IPS panel which has the most benefit in fast moving game genres such as first person shooters, fighters, racing sims, real-time strategy, and sports. These type of games require very fast and precise movements, which an ultra-high refresh rate and fast response time monitor will put you ahead of your competition.
  • Perfection for any refresh rate
    Take on any game without tearing, stuttering, flicker, or artifacts. G-SYNC compatible dynamically matches the refresh rate of the display to the frame rate of the GPU. Unlike other solutions, its unrestricted refresh rate supports from zero Hertz up to the maximum supported by the LCD panel - so you can count on exceptional performance in every game.
  • Night vision engaged
    Whether your entire screen is dark, or just a few portions have heavy shadows. Let the world's first smart black tuner brighten your day by bringing out the fine details in dark areas.
  • Tailored for the perfect fit
    The MSI Optix Gaming monitor is built to make you as comfortable as possible while gaming. Through adjustments of tilting (-5°~20°), you can easily change the position of the monitor for maximum ergonomics and optimum viewing experiences.
  • True color
    The Optix series gaming monitors have more gamut coverage compared to general monitors. Gameplay colors and details will look more realistic and refined, pushing immersion to its limits.
  • From edge to edge
    With a super narrow bezel, enjoy the best immersion possible in the latest games with a multi-monitor 180-degree setup. Enjoy better continuity between screens while playing games, working, or general computing.
  • Choose your gaming style
    MSI Optix series gaming monitors offers several modes to choose from. Gamers can choose the mode based on the type of game played to experience the best visual effects.
  • 178 degrees of wide viewing angle
    By having a large viewing angle, MSI gaming monitors has more leeway for placing your monitor in your setup without giving up the optimal viewing experience. Colors and details will stay sharp at more angles compared to other monitors with less viewing angles.
  • Anti-flicker technology
    Generic monitor displays normally have a flicker-rate of about 200-times per second, which is unnoticeable to the naked eye, but can cause fatigue over time. Certificated by TÜV Rheinland, MSI Anti-Flicker technology provides a very comfortable viewing experience by reducing the amount of flicker.
MSI Optix G242 - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/403380
Energy Class
Class F
Power Consumption (On mode)
23 W
Adaptive-Sync Technology
NVIDIA G-SYNC Compatible
5-way joystick
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 144 Hz
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
4 ms (grey-to-grey), 1 ms (MPRT)
Gaming
Colour Support
16.7 million colours (8-bit)
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
AC 100 - 240 V (50 - 60 Hz)
54.03 cm x 21.82 cm x 41.16 cm
3.33 kg
DisplayPort 1.2a, CIE1931, CIE1976
3-year warranty
Display Type
Energy Class
Class F
Diagonal Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
48 - 144 Hz
Horizontal Refresh Rate
30 - 180 kHz
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Frameless, game mode, blue light reduction, Wide Colour Gamut, MSI Anti-Flicker, night vision mode
54.03 cm x 21.82 cm x 41.16 cm - with stand
3.33 kg
Input
5-way joystick
DisplayPort 1.2a , 2 x HDMI , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable
Security Slot Type
Kensington security slot
Input Voltage
23 W
23 kWh/1000h
Dimensions & Weight Details
With stand - width: 54.03 cm - depth: 21.82 cm - height: 41.16 cm - weight: 3.33 kg , Without stand - width: 54.02 cm - depth: 5.71 cm - height: 32.82 cm
Shipping Width
62.1 cm
Shipping Depth
18.7 cm
Shipping Height
43.4 cm
Shipping Weight
5 kg
Limited warranty - 3 years
