MSI Optix G241V E2 Gaming Monitor
Quicklinx: GZ5ZWS00 Mfr#: 9S6-3BA71T-018
Visualize victory with the MSI Optix G241V E2 esports gaming monitor. Equipped with a 1920x1080, 75Hz refresh rate, 1ms response time panel, Optix G241V E2 will give you the competitive edge you need. Built with FreeSync technology, Optix G241V E2 can match the display's refresh rate with your GPU for ultra-smooth gameplay. Reach the peak of immersion with the latest technologies built into MSI gaming monitors.
  • 75Hz refresh rate + 1ms response time
    Optix monitors are equipped with a 75Hz refresh rate and 1ms response time IPS panel which has the most benefit in fast moving game genres, such as first-person shooters, fighters, racing sims, real-time strategy, and sports. These types of games require very fast and precise movements, so an ultra-high refresh rate and fast response time monitor will put you ahead of your competition.
  • AMD FreeSync technology
    Gaming shouldn't be a choice between choppy gameplay or broken frames. With MSI Optix series gaming monitors, it doesn't have to be. Get fluid, artifact-free performance at virtually any framerate with AMD FreeSync technology.
  • Tailored for the perfect fit
    The MSI Optix gaming monitor is built to make you as comfortable as possible while gaming. Through adjustments of tilting (-5°~20°), you can easily change the position of the monitor for maximum ergonomics and optimum viewing experiences.
  • 178 degrees of wide viewing angle
    By having a large viewing angle, MSI gaming monitors has more leeway for placing your monitor in your setup without giving up the optimal viewing experience. Colors and details will stay sharp at more angles compared to other monitors with less viewing angles.
  • Anti-Flicker technology
    Generic monitor displays normally have a flicker rate of about 200 times per second, which is unnoticeable to the naked eye, but can cause fatigue over time. MSI Anti-Flicker technology provides a very comfortable viewing experience by reducing the amount of flicker.
MSI Optix G241V E2 - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class E
Energy Consumption per Year
35 kWh
Power Consumption (On mode)
18 W
Adaptive-Sync Technology
AMD FreeSync
5-way joystick
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
4 ms (grey-to-grey), 1 ms (MPRT)
Gaming
Colour Support
16.7 million colours
Colour Gamut
102.4% Rec 709 (CIE 1976), 102.4% sRGB (CIE 1976), 104.93% NTSC (CIE 1931), 104.93% sRGB (CIE 1931), 77.35% DCI-P3 (CIE 1931), 77.35% Rec 709 (CIE 1931), 77.77% Adobe RGB (CIE 1931), 81.6% DCI-P3 (CIE 1976), 87.8% Adobe RGB (CIE 1976), 89.3% NTSC (CIE 1976)
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
AC 100-240 V (50 - 60 Hz)
54.03 cm x 21.96 cm x 42.26 cm
3.3 kg
CB, DisplayPort 1.2a, CIE1976
3-year warranty
Display Type
Energy Class
Class E
35 kWh
Diagonal Size
23.8"
AMD FreeSync
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
47 - 77 Hz
Horizontal Refresh Rate
30 - 100 kHz
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Frameless, game mode, blue light reduction, Wide Colour Gamut, MSI Anti-Flicker, night vision mode, 8-bit(6-bit + FRC) Colour Depth
54.03 cm x 21.96 cm x 42.26 cm - with stand
3.3 kg
Input
5-way joystick
HDMI , DisplayPort 1.2a , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable
Security Slot Type
Kensington security slot
Input Voltage
18 W
18 kWh/1000h
Power Consumption (Typical)
25 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 54.03 cm - depth: 21.96 cm - height: 42.26 cm - weight: 3.3 kg , Without stand - width: 54.03 cm - depth: 6.55 cm - height: 32.82 cm
Shipping Width
60.6 cm
Shipping Depth
17.2 cm
Shipping Height
40.9 cm
Shipping Weight
5 kg
Limited warranty - 3 years
