Visualize victory with the MSI Optix G241V E2 esports gaming monitor. Equipped with a 1920x1080, 75Hz refresh rate, 1ms response time panel, Optix G241V E2 will give you the competitive edge you need. Built with FreeSync technology, Optix G241V E2 can match the display's refresh rate with your GPU for ultra-smooth gameplay. Reach the peak of immersion with the latest technologies built into MSI gaming monitors.
75Hz refresh rate + 1ms response time
Optix monitors are equipped with a 75Hz refresh rate and 1ms response time IPS panel which has the most benefit in fast moving game genres, such as first-person shooters, fighters, racing sims, real-time strategy, and sports. These types of games require very fast and precise movements, so an ultra-high refresh rate and fast response time monitor will put you ahead of your competition. -
AMD FreeSync technology
Gaming shouldn't be a choice between choppy gameplay or broken frames. With MSI Optix series gaming monitors, it doesn't have to be. Get fluid, artifact-free performance at virtually any framerate with AMD FreeSync technology. -
Tailored for the perfect fit
The MSI Optix gaming monitor is built to make you as comfortable as possible while gaming. Through adjustments of tilting (-5°~20°), you can easily change the position of the monitor for maximum ergonomics and optimum viewing experiences. -
178 degrees of wide viewing angle
By having a large viewing angle, MSI gaming monitors has more leeway for placing your monitor in your setup without giving up the optimal viewing experience. Colors and details will stay sharp at more angles compared to other monitors with less viewing angles. -
Anti-Flicker technology
Generic monitor displays normally have a flicker rate of about 200 times per second, which is unnoticeable to the naked eye, but can cause fatigue over time. MSI Anti-Flicker technology provides a very comfortable viewing experience by reducing the amount of flicker.
- MSI Optix G241V E2 - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Class
- Class E
- Energy Consumption per Year
- 35 kWh
- Power Consumption (On mode)
- 18 W
- Adaptive-Sync Technology
- AMD FreeSync
- 5-way joystick
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 75 Hz
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 100000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey), 1 ms (MPRT)
- Gaming
- Colour Support
- 16.7 million colours
- Colour Gamut
- 102.4% Rec 709 (CIE 1976), 102.4% sRGB (CIE 1976), 104.93% NTSC (CIE 1931), 104.93% sRGB (CIE 1931), 77.35% DCI-P3 (CIE 1931), 77.35% Rec 709 (CIE 1931), 77.77% Adobe RGB (CIE 1931), 81.6% DCI-P3 (CIE 1976), 87.8% Adobe RGB (CIE 1976), 89.3% NTSC (CIE 1976)
- Input Connectors
- HDMI, DisplayPort
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 100-240 V (50 - 60 Hz)
- Black
- 54.03 cm x 21.96 cm x 42.26 cm
- 3.3 kg
- CB, DisplayPort 1.2a, CIE1976
- 3-year warranty
- Display Type
- Energy Class
- Class E
- 35 kWh
- Diagonal Size
- 23.8"
- AMD FreeSync
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 47 - 77 Hz
- Horizontal Refresh Rate
- 30 - 100 kHz
- Gaming
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Frameless, game mode, blue light reduction, Wide Colour Gamut, MSI Anti-Flicker, night vision mode, 8-bit(6-bit + FRC) Colour Depth
- Black
- 54.03 cm x 21.96 cm x 42.26 cm - with stand
- 3.3 kg
Input
- 5-way joystick
- HDMI , DisplayPort 1.2a , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x HDMI cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 18 W
- Power Consumption SDR (On mode)
- 18 kWh/1000h
- Power Consumption (Typical)
- 25 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 54.03 cm - depth: 21.96 cm - height: 42.26 cm - weight: 3.3 kg , Without stand - width: 54.03 cm - depth: 6.55 cm - height: 32.82 cm
- Shipping Width
- 60.6 cm
- Shipping Depth
- 17.2 cm
- Shipping Height
- 40.9 cm
- Shipping Weight
- 5 kg
- Limited warranty - 3 years
