MSI Optix G241 Gaming Monitor
Quicklinx: GZ6CWS00 Mfr#: 9S6-3BA41T-006
Visualize victory with the MSI Optix G241 eSports gaming monitor. Equipped with a 1920x1080, 144 Hz Refresh rate, 1ms response time panel, the Optix G241 will give you the competitive edge you need. Built with FreeSync technology, the Optix G241 can match the display's refresh rate with your GPU for ultra-smooth gameplay.
  • True color
    The Optix series gaming monitors have more gamut coverage compared to general monitors. Gameplay colors and details will look more realistic and refined, pushing immersion to its limits.
  • Night vision engaged
    Whether your entire screen is dark, or just a few portions have heavy shadows. Let the world's first smart black tuner brighten your day by bringing out the fine details in dark areas.
  • Tear free
    Gaming shouldn't be a choice between choppy gameplay or broken frames. With MSI Optix series gaming monitors, it doesn't have to be. Get fluid, artifact-free performance at virtually any framerate with AMD FreeSync technology.
  • Tailored for the perfect fit
    The MSI Optix Gaming monitor is built for extreme comfort while gaming. Easily tilt (-5°~20°) your monitor to change the position for maximum ergonomics and optimal viewing experiences.
  • Anti-Flicker technology
    Generic monitor displays normally have a flicker-rate of about 200-times per second, which is unnoticeable to the naked eye, but can cause fatigue over time. MSI Anti-Flicker technology provides a very comfortable viewing experience by reducing the amount of flicker.
  • From edge to edge
    With a super narrow bezel, enjoy the best immersion possible in the latest games with a multi-monitor 180 degree setup. Enjoy better continuity between screens while playing games, working, or general computing.
  • 178 degrees of wide viewing angle
    By having a large viewing angle, MSI gaming monitors has more leeway for placing your monitor in your setup without giving up the optimal viewing experience. Colors and details will stay sharp at more angles compared to other monitors with less viewing angles.
MSI Optix G241 - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/403376
Energy Class
Class F
Power Consumption (On mode)
20 W
Adaptive-Sync Technology
AMD FreeSync
5-way joystick
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 144 Hz
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
1 ms
Gaming
Colour Support
16.7 million colours
Colour Gamut
128% sRGB, 95% DCI-P3 wide
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
54.03 cm x 21.96 cm x 42.26 cm
3.3 kg
Display Type
Energy Class
Class F
Diagonal Size
23.8"
AMD FreeSync
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
1 ms
Horizontal Refresh Rate
30 - 100 kHz
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Blue light reduction, Wide Colour Gamut, MSI Anti-Flicker, frameless bezel design, night vision mode, 3-sided bezeless
3.3 kg
Input
5-way joystick
DisplayPort , Headphones , 2 x HDMI
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
Security Slot Type
Kensington security slot
Input Voltage
20 W
20 kWh/1000h
Power Consumption (Typical)
25 Watt
Shipping Width
60.6 cm
Shipping Depth
17.2 cm
Shipping Height
40.9 cm
Shipping Weight
5 kg
