Visualize victory with the MSI Optix G241 eSports gaming monitor. Equipped with a 1920x1080, 144 Hz Refresh rate, 1ms response time panel, the Optix G241 will give you the competitive edge you need. Built with FreeSync technology, the Optix G241 can match the display's refresh rate with your GPU for ultra-smooth gameplay.
True color
The Optix series gaming monitors have more gamut coverage compared to general monitors. Gameplay colors and details will look more realistic and refined, pushing immersion to its limits. -
Night vision engaged
Whether your entire screen is dark, or just a few portions have heavy shadows. Let the world's first smart black tuner brighten your day by bringing out the fine details in dark areas. -
Tear free
Gaming shouldn't be a choice between choppy gameplay or broken frames. With MSI Optix series gaming monitors, it doesn't have to be. Get fluid, artifact-free performance at virtually any framerate with AMD FreeSync technology. -
Tailored for the perfect fit
The MSI Optix Gaming monitor is built for extreme comfort while gaming. Easily tilt (-5°~20°) your monitor to change the position for maximum ergonomics and optimal viewing experiences. -
Anti-Flicker technology
Generic monitor displays normally have a flicker-rate of about 200-times per second, which is unnoticeable to the naked eye, but can cause fatigue over time. MSI Anti-Flicker technology provides a very comfortable viewing experience by reducing the amount of flicker. -
From edge to edge
With a super narrow bezel, enjoy the best immersion possible in the latest games with a multi-monitor 180 degree setup. Enjoy better continuity between screens while playing games, working, or general computing. -
178 degrees of wide viewing angle
By having a large viewing angle, MSI gaming monitors has more leeway for placing your monitor in your setup without giving up the optimal viewing experience. Colors and details will stay sharp at more angles compared to other monitors with less viewing angles.
- MSI Optix G241 - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/403376
- Energy Class
- Class F
- Power Consumption (On mode)
- 20 W
- Adaptive-Sync Technology
- AMD FreeSync
- 5-way joystick
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 144 Hz
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 100000000:1 (dynamic)
- Response Time
- 1 ms
- Gaming
- Colour Support
- 16.7 million colours
- Colour Gamut
- 128% sRGB, 95% DCI-P3 wide
- Input Connectors
- 2xHDMI, DisplayPort
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- 54.03 cm x 21.96 cm x 42.26 cm
- 3.3 kg
- Display Type
- Energy Class
- Class F
- Diagonal Size
- 23.8"
- AMD FreeSync
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- 1 ms
- Horizontal Refresh Rate
- 30 - 100 kHz
- Gaming
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Blue light reduction, Wide Colour Gamut, MSI Anti-Flicker, frameless bezel design, night vision mode, 3-sided bezeless
- 3.3 kg
Input
- 5-way joystick
- DisplayPort , Headphones , 2 x HDMI
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Security Slot Type
- Kensington security slot
- Input Voltage
- 20 W
- Power Consumption SDR (On mode)
- 20 kWh/1000h
- Power Consumption (Typical)
- 25 Watt
- Shipping Width
- 60.6 cm
- Shipping Depth
- 17.2 cm
- Shipping Height
- 40.9 cm
- Shipping Weight
- 5 kg
