MSI Optix AG321CR 31.5" Curved Gaming Monitor
Quicklinx: GZ5BWS00 Mfr#: 9S6-3DB45H-006
Visualize your victory with the MSI AG321CR Curved Gaming monitor. Equipped with a 1920 x 1080 resolution, 165Hz refresh rate, 1ms response time panel, AG321CR will give you the competitive edge you need to take down your opponents. Built with AMD FreeSync Premium technology, AG321CR can match the display's refresh rate with your GPU for ultra-smooth gameplay. Make sure you can hit your mark with all the latest technologies built in the MSI Curved Gaming monitor for competitive play.
  • Curved for your viewing pleasure
    MSI Curved Gaming monitors use a curved display panel that has a curvature rate of R1500, which is the most comfortable and suitable for a wide range of applications from general computing to gaming. Curved panels also help with gameplay immersion, making you feel more connected to the entire experience.
  • 165Hz refresh rate and 1ms response time
    MSI gaming monitors are equipped with a 165Hz refresh rate and 1ms response time VA LED panel which has the most benefit in fast-moving game genres, such as first-person shooters, fighters, racing sims, real-time strategy, and sports. These types of games require very fast and precise movements, which an ultra-high refresh rate and fast response time monitor will put you ahead of your competition.
  • MSI Mystic Light: personalize your gaming rig
    With MSI Mystic Light, the Optix MAG series gaming monitor lights provide a soft ambient light that can easily be synced with any other Mystic Light enabled gaming product. Select any of the colors from the palette using your smartphone or the Mystic Light app to match your system style to your taste. Or just turn on gaming echo, letting your monitor back light dance to music you play on the computer.
  • 178 degrees of wide viewing angle
    By having a large viewing angle, MSI gaming monitors have more leeway for placing your monitor in your setup without giving up the optimal viewing experience. Colors and details will stay sharp at more angles compared to other monitors with less viewing angles.
  • Tear-free, stutter-free fluid gaming
    Gaming shouldn't be a choice between choppy gameplay or broken frames. With MSI Optix series gaming monitors, it doesn't have to be. Get fluid, artifact-free performance at virtually any framerate with AMD FreeSync technology.
  • Anti-Flicker technology
    Generic monitor displays normally have a flicker rate of about 200 times per second, which is unnoticeable to the naked eye, but can cause fatigue over time. MSI Anti-Flicker technology provides a very comfortable viewing experience by reducing the amount of flicker.
MSI Optix AG321CR - LED monitor - curved - Full HD (1080p) - 31.5"
LED-backlit LCD monitor - 31.5"
Energy Class
Class F
Energy Consumption per Year
68 kWh
Power Consumption (On mode)
29 W
Curved Screen
Adaptive-Sync Technology
5-way joystick
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 (DisplayPort: 165 Hz, HDMI: 144 Hz)
Pixel Pitch
0.36375 mm
Brightness
250 cd/m²
Contrast Ratio
4000:1 / 100000000:1 (dynamic)
Response Time
4 ms (grey-to-grey), 14 ms (tr - tf), 1 ms (MPRT)
Gaming
Colour Support
16.7 million colours (8-bit)
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
71 cm x 28.6 cm x 46.5 cm
6.59 kg
BSMI, CB, EMC, FCC, MEPS, LVD, RCM, DisplayPort 1.2, HDCP 2.2
3-year warranty
Display Type
Energy Class
Class F
68 kWh
Diagonal Size
31.5"
Curved Screen
Yes (1500R)
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.36375 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
48 - 165 Hz
Horizontal Refresh Rate
30 - 200 kHz
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, frameless bezel design, night vision mode, MSI Mystic Light, Gaming Mode
71 cm x 28.6 cm x 46.5 cm - with stand
6.59 kg
Input
5-way joystick
2 x HDMI , DisplayPort , Headphones , USB 2.0 (Type B)
Mechanical
Tilt Angle
-5/+20
Swivel Angle
60
Rotation Angle
10
Height Adjustment
90 mm
VESA Mounting Interface
75 x 75 mm
1 x HDMI cable , 1 x USB-A to USB-B cable
Input Voltage
29 W
29 kWh/1000h
Power Consumption (Typical)
46 Watt
Power Consumption Stand by
0.33 Watt
Power Consumption (Off Mode)
0.28 Watt
Dimensions & Weight Details
Without stand - width: 71 cm - depth: 10.3 cm - height: 41.8 cm
Shipping Width
94.3 cm
Shipping Depth
17.1 cm
Shipping Height
53.9 cm
Shipping Weight
8.98 kg
Limited warranty - 3 years
