Curved panel for enhanced immersion
MSI gaming displays use an 1800R curved slab, which is simply the most comfortable and suitable format for a wide variety of applications, from office work to gaming. The curved screen is also ideal for game immersion, giving you a more realistic experience. -
144 hz refresh rate
The VA panel delivers a refresh rate of 144 Hz with a response time of 1 ms, making it an ideal choice for fans of fps, racing and sports games. Indeed, these games require fast, precise movements, which will be ensured by a high refresh rate and reduced response time. -
Find the most comfortable position
Optix MAG monitors will enhance your gaming sessions by offering you the most comfortable and ergonomic experience possible. In fact, you can adjust their angle of inclination, rotation and height to find the position that suits you best for your gaming. -
Slimmer edges
With their ultra-thin borders, Optix MAG monitors guarantee a perfectly continuous image when using multiple screens. This not only helps you feel more immersed in your game or film, but also makes working more enjoyable. -
Smoother gaming with AMD FreeSync technology
AMD FreeSync technology ensures the smoothest possible images for your video game. This technology synchronizes the screen refresh rate with the AMD graphics card to prevent tearing and jerking during your game. So you can enjoy your game the way it should be enjoyed. -
Anti-flicker technology
Although it's hard to notice, the flicker rate of a standard screen is 200 per second. This flicker puts pressure on your eyes and can lead to blurred vision and eyestrain. To avoid this, Optix MAG monitors feature technology that reduces the flicker rate and ensures greater comfort of use. -
Blue light protection
Optix MAG monitors are optimized to reduce the blue light emitted by the screen, which can be harmful to the eyes. Thanks to dedicated technology, you'll be able to play for hours on end without experiencing eyestrain.
- MSI Optix AG321CQR - LED monitor - curved - 31.5"
- LED-backlit LCD monitor - 31.5"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/400674
- Energy Class
- Class G
- Energy Consumption per Year
- 68 kWh
- Power Consumption (On mode)
- 40 W
- Curved Screen
- Adaptive-Sync Technology
- VESA Adaptive-Sync
- 5-way joystick, USB 3.2 Gen 1 hub
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- UWQHD 2560 x 1440 (DisplayPort: 165 Hz, HDMI: 144 Hz)
- Pixel Pitch
- 0.2724 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1 / 100000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey), 1 ms (MPRT), 21 ms (tr - tf)
- Gaming
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 105.84% Adobe RGB (CIE 1976), 107.83% NTSC (CIE 1976), 123.62% sRGB (CIE 1976), 128.68% sRGB (CIE 1931), 91.14% NTSC (CIE 1931), 94.86% DCI-P3 (CIE 1931), 95.39% Adobe RGB (CIE 1931), 98.56% DCI-P3 (CIE 1976)
- Input Connectors
- 2xHDMI, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 71 cm x 28.6 cm x 46.5 cm
- 6.59 kg
- BSMI, CB, PSE Mark, MEPS, LVD, RCM, DisplayPort 1.2, CE/EMC, HDCP 2.2, CIE1931, CIE1976
- 3-year warranty
- Display Type
- Energy Class
- Class G
- Energy Class (HDR)
- Class G
- 68 kWh
- Diagonal Size
- 31.5"
- Curved Screen
- Yes (1500R)
- Built-in Devices
- USB 3.2 Gen 1 hub
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2724 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 30 - 165 Hz
- Horizontal Refresh Rate
- 90.9 - 242 kHz
- Gaming
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Adaptive-Sync technology, frameless bezel design, HDR Ready technology, MSI Mystic Light, Gaming Mode, 10-bit(8-bit + FRC) Colour Depth
- Black
- 71 cm x 28.6 cm x 46.5 cm - with stand
- 6.59 kg
Input
- 5-way joystick
- 2 x HDMI (HDCP 2.2) , DisplayPort 1.2 (HDCP 2.2) , Headphones , USB 3.2 Gen 1 (Type A)
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 60
- Rotation Angle
- 10
- Height Adjustment
- 90 mm
- VESA Mounting Interface
- 75 x 75 mm
- Cables Included
- 1 x HDMI cable , 1 x USB-A to USB-B cable , 1 x power cable , 1 x power adapter
- Input Voltage
- 40 W
- Power Consumption SDR (On mode)
- 40 kWh/1000h
- Power Consumption HDR (On mode)
- 51 kWh/1000h
- Power Consumption (Typical)
- 46 Watt
- Power Consumption Stand by
- 0.33 Watt
- 0.28 Watt
- Included Software
- MSI Gaming OSD App
- Dimensions & Weight Details
- Without stand - width: 71 cm - depth: 10.3 cm - height: 41.8 cm
- Shipping Width
- 94.3 cm
- Shipping Depth
- 17.1 cm
- Shipping Height
- 53.9 cm
- Shipping Weight
- 8.98 kg
- Limited warranty - 3 years
